Port Channel on Fiber and Ethernet Interfaces
Hello All,
Can we configure Single Port Channel on Fiber and Ethernet Interfaces ?
I think "YES", Could someone please confirm ?
Prasanna Kumar Desireddy
Leo Laohoo
I think you need to read this: Cisco EtherChannel Technology
ahmedshoaib
Level 4
Level 4
UTP & Fiber both are Ethernet technology, only difference is layer 1 physical media where actual traffic/data flow.
You can configure the port-channel on UTP & Fiber at same time in case all parameters should be same (I.e port speed, duplex settings & etc). If any parameter mismatched the port will not create port channel.
Thanks & Best regards.
