Port Channel Settings
sdawson35
Trying to setup a port channel between to Catalyst 6506's, the commands are accepted but the channeling doesn't work.
The commands I used are :
set trunk 1/1,1/2 on dot1q
set port channel 1/1,1/2 mode on
I have set these commands on both switches.
One Cat is running 8.4.5 and the other 8.5.5.
What am I doing wrong ?
Scott.
9 Replies 9
mahmoodmkl
Level 7
Level 7
Can u give the admin qroup number and check.
Mahmood
Hi Mahmood,
Does the admin group number have to match on both Cats ?
Scott.
Scott
No it is only locally significant. Could you send output of
"sh channel info"
"sh trunk"
Jon
Hi Jon,
sh channel info
No ports channelling
sh trunk
* - indicates vtp domain mismatch
# - indicates dot1q-all-tagged enabled on the port
$ - indicates non-default dot1q-ethertype value
Port Mode Encapsulation Status Native vlan
1/1 on dot1q trunking 1
1/2 on dot1q trunking 1
2/1 on dot1q trunking 1
2/3 on dot1q trunking 1
2/5 on dot1q trunking 1
2/7 on dot1q trunking 1
2/9 on dot1q trunking 1
2/16 on dot1q trunking 1
3/2 on dot1q trunking 1
3/3 on dot1q trunking 1
3/4 on dot1q trunking 1
3/5 on dot1q trunking 1
15/1 nonegotiate isl trunking 1
Kevin Dorrell
Level 10
Level 10
Check the configurations on 1/1 and 1/2 match exactly before you try and put them into a channel. Mismatched VLAN lists, for example, can stop them forming a channel.
The other end of the channel must also be configured "on". The "on" option stops the negotiation, so "on" will not work opposite "desirable" or "auto".
Kevin Dorrell
Luxembourg
Hi Kevin,
Have found one differaence between the 2 ports on one of the cats !!.
Port Vlans allowed and active in management domain
1/1 1-3,5,8-9,16-22,26,32,64-66,101,104,109,116-122,126-128,204,802,901
1/2 1-3,5,8-9,16-22,26,32,64-66,101,104,109,116-122,126-128,204,802,901
Port Vlans in spanning tree forwarding state and not pruned
1/2
I don't think that is the source of the problem. The allowed VLAN list are the same unless I missed something. Just that one of the links has been put in standby, which is what you would expect from Spanning Tree when you have two parallel links.
Oh, you could check that the ports actually support channel? For example, if I remember right, the ports on a 5500 sup card do not support channel. Try show port capabilities 1/1
Kevin Dorrell
Luxembourg
These are Cat6500 series (6506) with SupII & MSFCII.
Looks like it should work ?.
sh port capabilities 1/1
Model WS-X6K-SUP2-2GE
Port 1/1
Type 1000BaseSX
Auto MDIX no
AuxiliaryVlan no
Broadcast suppression percentage(0-100)
Channel yes
COPS port group 1/1-2
CoS rewrite yes
Dot1q-all-tagged yes
Dot1x yes
Duplex full
Fast start yes
Flow control receive-(off,on,desired),send-(off,on,desired)
Inline power no
Jumbo frames yes
Link debounce timer yes
Link debounce timer delay yes
Membership static,dynamic
Port ASIC group 1/1-2
Port VLAN Mapping Group: 1/1-2 Maximum Allowed Mappings: 32
Port VLAN Mapping Supported Trunk Type: dot1q
QOS scheduling rx-(1p1q4t),tx-(1p2q2t)
Security yes
SPAN source,destination
Speed 1000
Sync restart delay yes
ToS rewrite DSCP
Trunk encap type 802.1Q,ISL
glen.grant
USe the following. The ports and speed settings must be exactly the same on both sides
set trunk 1/1-2 on dot1q
set port channel 1/1-2 mode desirable non-silent
