Port Forwarding. Please help
Jossnaz321
Community Member
Hello
I'm looking for a guide to do port forwarding with the pix 501.
Well here is what I've done so far:
I tried to add a translation rule to forward the port 7895 to the ip address 192.168.1.3
I used
static (inside,outside) tcp 84.73.34.77 7895 192.168.1.3 7895 netmask 255.255.255.255
and then i got it like this
<img src="http://www.bildercache.de/bild/20061130-171046-93.gif" alt="" border="0" />
But as soon as I try to click on this rule and change something, lets say the port number i get an error, saying I'm in conflict with the older given rule:
<img src="http://www.bildercache.de/bild/20061130-171008-94.gif" alt="" border="0" />
I read that I have to add an access list too. I've done that by writing
access-group outside-inbound in interface outside
access-list outside-inbound permit tcp any host 84.73.34.77 eq 7995
my access rules look like this:
img src="http://www.bildercache.de/bild/20061130-180133-61.gif" alt="" border="0" /> <br />
What did I do wrong? I'm very frustrated and hope someone can help me
thanks
hi
thanks a lot for the answer
Well, i still have the problem
As I mentioned and shown in the picture, there is a rule conflicting with the rule I want to add.
if I remove the other rule the internetconnection fails totally. I have to do some testing too but i'll rate you as soon as I got it and I hope thats soon.
I added the rule and the other rule is below which is conflicting.
but get the error
greetings
Jossnaz321
Community Member
I got the problem solved
and as I think a picture says more than 100 commands.
For port forwarding forward redirect redirection with cisco pix 501 using pdm you do as in the pictures attached.
I forwarded port 15177 in this example. You can use it to get a good id with bittorrent emule. No more low id, fast transfer now.
in translation rules open the wanted port and in access rules add a rule allowing any port to the ip.
