Port in suspended mode between cisco 9300 and avaya
arouna.kikone1
Hi ALL
I have two Cisco 9300X-24Y-E stacked switches. I want to implement etherchannel between my cisco switches with an avaya switch.
After the configurations and the interconnection of the switches, the port-channel goes into "suspended" mode.
Note that the cisco 9300 switch does not allow me to type the command "Switchport trunk encapsulation dot1q".
Need your help to solve this problem which prevents me from evolving in my project.
below is the ports config in etherchannel:
CONFIGURE ETHERCHANNEL LACP
SW_SI_DC_NTX(config)# interface range twentyfiveGigE1/0/23-24,twentyfiveGigE2/0/23-2/0/24
SW_SI_DC_NTX(config-if-range)#channel-protocol lacp
SW_SI_DC_NTX(config-if-range)#channel-group 40 mode active
SW_SI_DC_NTX(config-if-range)# exit
SW_SI_DC_NTX(config)#interface port-channel 40
SW_SI_DC_NTX(config-if)#switchport mode trunk
interface Port-channel 40
interface TwentyFiveGigE1/0/23
interface TwentyFiveGigE1/0/24
interface TwentyFiveGigE2/0/23
interface TwentyFiveGigE2/0/24
SW_SI_DC_NTX#sh running-config interface port-channel 40
Building configuration...
Current configuration : 68 bytes
duplex full
end
SW_SI_DC_NTX#sh etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
A - formed by Auto LAG
Number of channel-groups in use: 2
Number of aggregators: 2
Group Port-channel Protocol Ports
1 Po1(SD) -
40 Po40(SD) LACP Twe1/0/23(D) Twe1/0/24(s)
Twe2/0/23(D) Twe2/0/24(D)
SW_SI_DC_NTX#show interfaces twentyFiveGigE 1/0/24
TwentyFiveGigE1/0/24 is up, line protocol is down (suspended)
Hardware is Twenty Five Gigabit Ethernet, address is c02c.17fd.7e98 (bia c02c.17fd.7e98)
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-SR
input flow-control is on, output flow-control is unsupported
Last input 00:00:00, output 00:00:19, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 31000 bits/sec, 49 packets/sec
3603671 packets input, 382205571 bytes, 0 no buffer
Received 3455251 broadcasts (449542 multicasts)
6 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 449542 multicast, 0 pause input
12949 packets output, 1488007 bytes, 0 under runs
Output 0 broadcasts (12949 multicasts)
0 output errors, 0 collisions, 3 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
SW_SI_DC_NTX#
72 Replies 72
righit, that´s good. And did you try with mode "passive" and or "on"? on the cisco side?
@Flavio Miranda  yes I tried with mode "passive" but it's the same.
And mode "on" ?
@Flavio Miranda  I have not tried the mode "on" . Can we use the mode "on" with the standard LACP protocol between cisco switch and third party?
 Yes as the Avaia actually seems not running LACP at all.
I sent you the config on the avaya switch as an attached file.
it is the LACP protocol that has been configured.
I'll share it with you again as an attachment.
Sorry, what I meant is that the Avaya seems not to be understanding the LACP from cisco side.
I would try mode "on" just to make sure
@Flavio Miranda Ah ok I understand what you mean.
Alright I'll try that when I'm on site and get back to you.
I have found in another forum this config for Avaya side
lacp key port 2/23,4/23 10
lacp mode port 2/23, 4/23 passive
lacp aggregation port 2/23, 4/23 enable
https://community.meraki.com/t5/Switching/Link-Aggregation-between-Meraki-MS425-16-and-Avaya-Switches/m-p/69312
They are connecting with Meraki but it might also help you.
Show lacp internal
Share this
HI @MHM Cisco World @Flavio Miranda
Below is the output of the " show lacp internal" command
SW_SI_DC_NTX#show lacp internal
Flags: S - Device is requesting Slow LACPDUs
F - Device is requesting Fast LACPDUs
A - Device is in Active mode P - Device is in Passive mode
Channel group 2
LACP port Admin Oper Port Port
Port Flags State Priority Key Key Number State
Twe1/0/21 SA down 32768 0x2 0x0 0x116 0x4D
Twe1/0/22 FA down 32768 0x2 0x2 0x117 0xF
Channel group 40
Twe1/0/23 SA down 32768 0x28 0x0 0x118 0x4D
Twe1/0/24 SA susp 32768 0x28 0x28 0x119 0x3D
Twe2/0/23 SA down 32768 0x28 0x0 0x218 0x4D
Twe2/0/24 SA down 32768 0x28 0x0 0x219 0x4D
SW_SI_DC_NTX#
 Hi @arouna.kikone1
The output only show that the port is in suspended.  Did you try with mode "on" as we talked last week?
And what about the config I share related to the avaiya side?
lacp mode port x/x  passive
lacp aggregation port x/x  enable
In order to test this config on Avaya you need to change cisco to passive mode also.
@Flavio Miranda @MHM Cisco World
I changed the configuration to "on" mode and the port status changed from S to P.
what does this mean please?
Means this:
After that, could you communicate? How are you testing anyway, instead looking the interface status?
see below the output of "sh int port-channel 2" command
SW_SI_DC_NTX#show interfaces port-channel 2
Port-channel2 is up, line protocol is up (connected)
Hardware is EtherChannel, address is c02c.17fd.7e95 (bia c02c.17fd.7e95)
Keepalive set (10 sec)
Full-duplex, 10Gb/s, link type is auto, media type is N/A
Members in this channel: Twe1/0/21
Last input never, output 00:00:00, output hang never
5 minute output rate 4000 bits/sec, 8 packets/sec
149 packets input, 13137 bytes, 0 no buffer
Received 149 broadcasts (149 multicasts)
0 watchdog, 149 multicast, 0 pause input
5014 packets output, 367868 bytes, 0 underruns
Output 0 broadcasts (5014 multicasts)
0 output errors, 0 collisions, 2 interface resets
SW_SI_DC_NTX#
