05-27-2011 09:02 AM - edited 03-06-2019 05:14 PM
I have a WS-C3750G-24PS that port (GigabitEthernet1/0/26 ) keeps disconnecting. The last time it happened I did a shut/no shut and it went back up. My opinion is that it is SPF. What debug commands or commands period can I use to isolate if this is a hardware issue or not?
05-27-2011 11:55 AM
not sure of some debug commands... but we can try the sfp in the port gig1/0/26 to another working port to check if we stil face the issue... if yes then issue is with sfp
-balaji
05-27-2011 12:03 PM
you can test the port if it has an IP address configured on it. Change the port from layer-2 to layer-3 (routed port), put an IP address on it and try this command
"test interface giga 1/0/26"
if the port is working you should see this
!!!!!!!!!!!!!!!!!!!!!!!!!!! passed
05-27-2011 09:18 PM
OUT OF TOPIC
Hey Reza,
Forgot to say "Congratulations" for getting a new RED badge.
05-28-2011 06:25 AM
Hi Leo,
Thanks a lot my friend!!!!
