port security issue
Asim Afzal
Level 4
Level 4
please find the output of the show commands below.
Before resetting the port-security  on the interface  --
UNB-Deira-Br-2950SW2# sh mac-address-table | i   0/7
   1    0007.3be4.0171     STATIC      Fa0/7
117    0007.3be4.0171    STATIC       Fa0/7
Same MAC coming from port fa 0/7
UNB-Deira-Br-2950SW2#sh port-security
Secure Port  MaxSecureAddr  CurrentAddr  SecurityViolation   Security Action
                (Count)       (Count)           (Count)
      Fa0/1              2            1                   0         Restrict
      Fa0/2              2            2                   0         Restrict
      Fa0/3              2            1                   0         Restrict
      Fa0/4              2            1                   0         Restrict
      Fa0/5              2            0                   0         Restrict
      Fa0/6              2            1                   0         Restrict
      Fa0/7              2            2                3874         Restrict
      Fa0/8              2            2                   0         Restrict
      Fa0/9              2            2                   0         Restrict
     Fa0/10              2            2                   0         Restrict
UNB-Deira-Br-2950SW2#sh run int fa 0/7
Building configuration...
Current configuration : 440 bytes
interface FastEthernet0/7
switchport mode access
switchport voice vlan 117
switchport port-security
switchport port-security maximum 2
switchport port-security aging time 1440
switchport port-security violation restrict
switchport port-security aging type inactivity
storm-control broadcast level 20.00 18.00
storm-control action trap
spanning-tree portfast
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
end
Nov  26 08:48:19.254 AUH: %PORT_SECURITY-2-PSECURE_VIOLATION:  Security  violation occurred, caused by MAC address 000f.fef4.4dd5 on port   FastEthernet0/7.
Nov 26 08:48:24.758 AUH:  %PORT_SECURITY-2-PSECURE_VIOLATION:  Security violation occurred, caused  by MAC address 000f.fef4.4dd5 on port  FastEthernet0/7.
Nov  26 08:48:30.254 AUH: %PORT_SECURITY-2-PSECURE_VIOLATION:  Security  violation occurred, caused by MAC address 000f.fef4.4dd5 on port   FastEthernet0/7.
Nov 26 08:48:36.530 AUH:  %PORT_SECURITY-2-PSECURE_VIOLATION:  Security violation occurred, caused  by MAC address 000f.fef4.4dd5 on port  FastEthernet0/7.
Nov  26 08:48:51.602 AUH: %PORT_SECURITY-2-PSECURE_VIOLATION:  Security  violation occurred, caused by MAC address 000f.fef4.4dd5 on port   FastEthernet0/7.
Nov 26 08:49:00.582 AUH:  %PORT_SECURITY-2-PSECURE_VIOLATION:  Security violation occurred, caused  by MAC address 000f.fef4.4dd5 on port  FastEthernet0/7.
After resetting the port-security  on the interface  --
UNB-Deira-Br-2950SW2(config)#do sh mac-add | i  0/7
   1    000f.fef4.4dd5     STATIC      Fa0/7
andrewswanson
Level 11
Level 11
Hello - the mac address of the device in the voice vlan is non-cisco. its oui suggests tenovis as the manufacturer (Avaya?). Do your IP phones support cdp (if i recall,  'switchport voice vlan" command requires the IP phone to support cdp)
hth
andy
Sandeep Choudhary
HI Asim,
Make it  this one:
switchport port-security maximum 3 on port fa0/7 and then see the results.
Reagrds
please rate if it helps.
mahmoodmkl
Level 11
Level 11
As suggested by sandeep make it 3 because u need to consider the mac-address of the switch which is in-built in IP Phone.
