12-03-2012 06:22 PM - edited 03-07-2019 10:22 AM
This is my topology.
I have created two vlan (201 and 202)
I want to create an access-list on the layer 3 switch.
Server0 must be able to connect to server1 using HTTP only and deny any other ports.
Server1 must also be able to connect to Server0 using HTTP only and deny other ports.
Please do help me I don't know what I am doing wrong.
Thank you in advance
Below is my config:
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
ip routing
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 201
switchport mode access
interface FastEthernet0/2
switchport access vlan 202
interface Vlan1
no ip address
shutdown
interface Vlan201
ip address 10.10.10.1 255.255.255.0
ip access-group 101 in
interface Vlan202
ip address 20.20.20.1 255.255.255.0
ip access-group 102 in
ip classless
access-list 101 permit tcp 10.10.10.0 0.0.0.255 20.20.20.0 0.0.0.255 eq www
access-list 102 permit tcp 20.20.20.0 0.0.0.255 10.10.10.0 0.0.0.255 eq www
line con 0
line vty 0 4
login
end
Solved! Go to Solution.
12-03-2012 07:21 PM
I believe your problem lies with return traffic. When 10.10.10.10 sends an http request to 20.20.20.20 all is fine. But when 20.20.20.20 replies to 10.10.10.10 it is using the source port of 80 and a different destination port.
So what should work is this:
access-list 101 permit tcp 10.10.10.0 0.0.0.255 20.20.20.0 0.0.0.255 eq www \\ When accessing the website on 20.20.20.0/24
access-list 101 permit tcp 10.10.10.0 0.0.0.255 eq www 20.20.20.0 0.0.0.255 \\ When replying to http requests from 20.20.20.0/24
access-list 102 permit tcp 20.20.20.0 0.0.0.255 10.10.10.0 0.0.0.255 eq www \\ When accessing the website on 10.10.10.0/24
access-list 102 permit tcp 20.20.20.0 0.0.0.255 eq www 10.10.10.0 0.0.0.255 \\ When replying to http requests from 10.10.10.24
12-03-2012 07:19 PM
It should be like ths.
access-list 101 permit tcp 10.10.10.10 0.0.0.0 20.20.20.20 0.0.0.0 eq www
access-list 102 permit tcp 20.20.20.20 0.0.0.0 10.10.10.10 0.0.0.0 eq www
12-03-2012 07:21 PM
12-03-2012 07:43 PM
Thank you very much for all your help.
@mahmoodmkl
thanks for the respose bro
i used
in order to allow all http connections from the 10.10.10.0 /24 network or 20.20.20.0/24.
@gabriel hill
Thank you for you help sir that fixed my problem.
I have another question regarding the config you game.
I needed to specify the return destination and port because I am using a layer 3 switch and it is stateless? correct sir?
also another question why do I need to put the return access-list in the Inward direction instead of out?
thanks
12-03-2012 08:02 PM
\\ I needed to specify the return destination and port because I am using a layer 3 switch and it is stateless? correct sir?
Yes that is correct. You could do some simple CBAC that would make this stateful.
\\ also another question why do I need to put the return access-list in the Inward direction instead of out?
Simply because it's easiest that way (At least for my brain, left-to-right kind of guy). You could make it work with the "out" direction but then your logic changes for your ACL's. The "in" and "out" direction is subject to where the traffic is coming from.
For example: Traffic coming from 10.10.10.0 going to 20.20.20.0
ACL "IN" vlan 201 THEN----> "OUT" vlan 202
So in the "out" direction on vlan 202 you would need to allow 10.10.10.0 to go to 20.20.20.0 (opposite of the "in" direction on vlan 202)
So to use the "OUT" direction you would have to reverse your ACL's. Simple apply 101 "OUT" on vlan 202 and ACL 102 "OUT" on vlan 101.
I hope this makes sense.
12-03-2012 08:30 PM
@gabriell Hill
Thank you very much for all the help I get it now
It has something to do with the three way handshake.
best regards and have a great day.
