Port Security Issue
Jose-Net
Visitor
Hi all.
We recently implemented port security on almost all of our access catalyst 2960-x switches, but are encountering some issues whereby if USER1 uses his laptop on a configured port-security port, he will be able to access internet (or any network resources) compared to if he uses his laptop on a different non-configured port-security switch whereby he wont be able to access any network resources (even ping fails) unless, port-security is turned off from his original access switch
Note:
1. Switches are trunked together
2. Access vlan is 1
Running-Config (Port Security Switch):
SW-01-SEC#sh run int gig1/0/1
Building configuration...
Current configuration : 265 bytes
interface GigabitEthernet1/0/1
 switchport mode access
 switchport voice vlan 100
 switchport port-security maximum 2
 switchport port-security mac-address sticky
 mls qos trust cos
 spanning-tree portfast
Running-Config (Non Port-Security Switch):
 interface GigabitEthernet1/0/37
 mls qos trust cos
Can anyone assist as to why this issue is happening?
Julio E. Moisa
I have not faced this issue before but you could try appling aging time under each interface with port security
switchport port-security aging type inactivity
switchport port-security aging time <aging time in minutes>
It will remove the inactive mac address into a specific time.
show port-security interface <interface> ; in order to see how it is applied.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
Thank you for your prompt reply. Unfortunately, this is not a viable solution as it will defeat the whole purpose of access control.
Is there any other solution you can think of that will do the trick?
Deepak Kumar
I am not sure, but theoretically, I can understand that maybe will face issue with port security with sticky. Please convert to dynamic.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Unfortunately, configuring static entry did not resolve the issue.
