portfast?
starmantwo
Community Member
On a 2960...what is the command to show if portfast is enable on the ports?
5 Replies 5
thanks for reply but i know how to put a port on portfast...i just wanted to know if there was any sh commands to display ports in portfast. Rather than doing a sh run...
Sorry about that, no its just the show run to verify.
Edit|
show spanning tree interface | in PortFast
Hi Lejoe,
I thought of that at first, but doing that will only show lines spanning-tree portfast and nothing more. It will not indicate which ports it is configured on.
Mark
Jeff,
You can use the "show spanning-tree interface faX/X detail" command. It will show portfast is enabled or disabled. I don't know of a command that will quickly display all the ports of a switch that are configured for portfast.
HTH,
Mark
