Portforwarding to DVR (Help)
firemonkey123
Hi all, I need help with portwarding on cisco 1841 to my dvr.
DVR: ip- 192.168.146.5/24, server port - 7777, 8888(mobile), http port - 80
I am able to remote to the dvr via public public using static nat, the browser would load the camera and ask to sign in, but i am not able to login as the DVR doesn't show up on the search and when I specified the ip and port, it said fail to connect. Please help, I think something wrong with my static nat or acl, need something else add to the config. Also the clock is always wrong, it doesn't update the time but it does update the date...
NPCISCO#sh run
Building configuration...
Current configuration : 1845 bytes
version 12.4
service password-encryption
hostname NPCISCO
boot-start-marker
boot-end-marker
enable secret 5 $1$70h8$wYku6QKYlHlaS7GZpp6vz.
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.146.1 192.168.146.99
ip dhcp pool LAN
   network 192.168.146.0 255.255.255.0
   default-router 192.168.146.1
   dns-server 8.8.8.8
ip name-server 8.8.8.8
interface FastEthernet0/0
 no ip address
 ip tcp adjust-mss 1452
 duplex auto
 speed auto
 pppoe enable
 pppoe-client dial-pool-number 1
interface FastEthernet0/1
 ip address 192.168.146.1 255.255.255.0
 ip access-group CAMERA in
 ip nat inside
 duplex auto
 speed auto
interface Dialer1
 ip address negotiated
 ip mtu 1452
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp pap sent-username 004b1d@biz password 7 04721F545F701F
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip nat inside source list NAT_ADDRESSES interface Dialer1 overload
ip nat inside source static udp 192.168.146.5 80 interface Dialer1 7777
ip nat inside source static tcp 192.168.146.5 80 interface Dialer1 8888
ip access-list standard NAT_ADDRESSES
 permit 192.168.146.0 0.0.0.255
ip access-list extended CAMERA
 permit ip 192.168.146.0 0.0.0.255 192.168.146.0 0.0.0.255
 permit ip any any
control-plane
banner motd ^C### NETRO Authorized Personnel Ony ###^C
line con 0
 exec-timeout 0 0
 password 7 04753B2526126F61
 logging synchronous
 login
line aux 0
line vty 0 5
 password 7 032A6B282F3C0263783D20
 login
ntp server 118.67.200.10
end
Much thanks in advance,
firemonkey123
Static Nat should be:
ip nat inside source static tcp 192.168.146.5 80 interface Dialer1 7777
Ahh finally got it to work on my own after much trials and errors. If those who having this issue, all I need was portwarding all the ports associated with the DVR hence 80, 7777, and 8888 like so
ip nat inside source static tcp/udp 192.168.146.5 80 interface Dialer1 80
ip nat inside source static tcp/udp 192.168.146.5 7777 interface Dialer1 7777
ip nat inside source static tcp/udp 192.168.146.5 8888 interface Dialer1 8888
