Ports in Supervisor Engine 720 10G
tookenyip12
Beginner
Beginner
The supervisor engine 720 for VSS comes with two X2-based 10 Gigabit Ethernet ports, two Gigabit Ethernet Small Form-Factor Pluggable (SFP) ports and one 10/100/1000 gigabit port. My question is are all the ports active at the same time?
What if I also have redundant supervisor engine in the chassis?
Thanks alot for the help.
Calin C.
Contributor
Contributor
Here it is:
http://www.cisco.com/en/US/products/ps9335/index.html
Allows two 10 Gigabit Ethernet and two Gigabit  Ethernet uplinks to be active simultaneously; with redundant  supervisors, allows all ten uplinks to be active
HTH,
Calin
Calin C.
Contributor
Contributor
Here it is:
HTH,
Calin
Hi sir, thank you very much.
Recognize Your Peers
