POST error Catalyst 2950
sappelhof
Community Member
I have a Catalyst 2950 series 12 prt. switch. When the switch is booting I receive the following error: "00:00:13: POST: Packet DA mismatch on port: 9"
What does this message means? Can I still use this port?
Kind regards,
5 Replies 5
nhabib
Level 11
Level 11
This is part of the power on self test(POST).
The switch sets the interface to loopback and sends
a packet. If anything is wrong or changed with
the packet then you get an error. In this case
the DA (destination address) was changed on
the received packet. I assume since this is a
switch they are referring to the layer2 address.
I would think this would indicate a possible hardware
failure.
sappelhof
Community Member
Hi Nabib,
Thanks for the information.
I thought also that this is a hardware issue.
Thanks again
sappelhof
Community Member
Hi Nabib,
Thanks again
sappelhof
Community Member
Hi Nabib,
Thanks again
