Power over ethernet on 2950 switch?
Ibbywannit
Hi to all my respected friends and gurus,
You guys have saved my butt numerous times - and i thank you all for that. Here's another one for you. I had a customer that couldn't reach his switch (2950)and we deduced that he may be running a standard image instead of an enhanced one. He's now asking me whether the enhanced image will support power over ethernet. i was under the impression that the IOS revision wouldn't make a difference - any clarification on that?
The IOS is 12.1 (6) by the way...
5 Replies 5
mattcalderon
Level 4
Level 4
You are correct. that model of switch does not support Power over Ethernet. You need to upgrade your hardware.
2960s do support POE
http://cisco.com/en/US/products/hw/switches/index.html
What about if he's using a "power injector?" (I don't know what one is but i heard someone saying that they managed to use POE with a power injector and some form of manual configuration)....
Thanks for all your help there Matt and i appreciate the swift reply. Please see the reflection in the ratings...
No problem and thanks for the kind rating. I hope that you have gotten all of your questions answered.
