Bookmark
Subscribe
1557
Power problem after remove from stack
denilson.mota
Hi community,
My switch WS3850-24XS-S can't power on after remove from the stack. The switch only boot when I connect the stack cables (power and data) or when I connect the second power supply.
I want to power on my switch standalone without stack, when I plug the power cable the switch start but no light on front only on the back (the fan light)
Any idea how can I start the switch without dual power or stack?
Thank you
2 Accepted Solutions
350 w power supply is not "supported" on those big 3850-24XS. You can plug them in, you can power them up but the switch won't accept the power because the minimum power they are meant to use is 715 w.
7 Replies 7
Leo Laohoo
What kind of power supply is currently installed in the WS3850-24XS? Is it a 350 watts?
PWR-C1-715WAC
What exact firmware is the stack running on?
But it sounds like CSCuz89095.
I have 3 WS3850-24XS-S, both have a 715W power supply and one have a 350W power supply, I saw now when u mentioned about the power. Now both switch start in standalone mode with 715W power supply. When I insert the 350W power supply alone the start but not booting, no light appear. seems like a mismatch devices from the fabric.
Yes minimum voltage require is 715W, the switch is brand new I remove from the box how can come with 350W power supply. maybe is a mistake from the fabric and I run around thinking that is an stack issue.
Thanks for your support.
Check the BoM or purchase order.
Someone needs to "override" this selection in CCW.
