04-01-2022 06:51 AM
Hello. I'm collecting equipment for the home Cisco lab. Have a problem with finding used cheap switches for lab, which run already on IOS 15.x or can be upgraded from 12.x to 15x. Can anybody come up with some suggestions? Will appreciate any suggestion.
Kind Regards
Jake
Solved! Go to Solution.
04-01-2022 08:33 AM - edited 04-01-2022 08:33 AM
15.0 can be installed on that device as pre the model - 3560V2
Layer 3 feature can be available in IPservice image
04-01-2022 07:08 AM
2960/G/S/X, 3560G/E/X, 3750G/E/X
2960C
3560CG
04-01-2022 07:13 AM
Thx for such quick response.
Which ones are layer 3 switches?
04-01-2022 07:42 AM
Will this one will accept upgrade do IOS 15 - it has 32 MB flash - https://www.router-switch.com/pdf/ws-c3560v2-48ts-s-datasheet.pdf
04-01-2022 08:45 AM
Thanks a lot !!! Now I need a router with IOS 15. Many people advising Cisco 1841 (but it's 12.x) somebody any alternatives, anyone? Please tell me how much eq I need I heard 3 switches with one L3 and two routers to get ready for CCNA and the next CCNP. Is that up to today's requirements?
BTW Sorry I haven't written it in one post.
Beginners mistake
Regards.
04-01-2022 09:48 AM
if you are not keen on hardware, why not use emulators GNS3/PNET/EVE ( CML- Cisco paid version 200$)
04-01-2022 10:06 AM
I like "live" experience. Besides that,I have very unpleasant neighbors
Just joking. The real deal is the thing for me. I was working with hardware installation a lot, never got the time to go from the software side. I was thinking about Router CISCO 2800 2821 1G/256 AdvipServic but it has only one port. So any ideas? Something with IOS 15 without ruining the home budget?
04-01-2022 04:54 PM
For router, get 1900 or 2900 series routers.
04-02-2022 11:03 PM - edited 04-02-2022 11:11 PM
Hey.
Will 15.0.2-SE11 IP BASE image is enough to work on 3560V2-24TS-S switch for CCNA / CCNP lab purposes or I need IP Services image?
04-03-2022 10:16 AM
Layer 2 some static should be ok, Look at the IP base freatures
