02-11-2018 05:12 PM - edited 03-08-2019 01:48 PM
Does Nexus 9000 series support FEX preprovisioning?
Solved! Go to Solution.
02-12-2018 06:38 AM
FEX pre-provisioning feature is not currently available on any of our Nexus 9000 switches unfortunately. There is an enhancement request, CSCun26267, for the addition of this feature to the Nexus 9000 portfolio but it has not been implemented yet and there is currently no target date/roadmap for the same.
Hope this helps!
- Andrea
02-11-2018 06:26 PM
I don't see it on the 9200 series but not sure about the 9300.
02-12-2018 06:38 AM
Hope this helps!
- Andrea
02-12-2018 06:41 AM
Thanks for the feedback Andrea!
03-08-2019 07:00 AM
I found that this feature in my use case is not that needed since the access ports on the fabric extenders come up on the Nexus 9k as "admin down" unlike on the N5k, where it comes up as up /up. Since its admin down, I can configure the access port to the desired vlan before "no shutdown" to bring it up thereby avoid blackholing traffic.
06-22-2023 11:50 PM
does this correspond to the setting of the global "system default switchport shutdown"-config-knob or are "new" FEX-Interfaces always admin-down?
06-22-2023 11:46 PM
Update for NXOS 10.2(5) @ Nexus 93360: Still no provisioning available
01-15-2025 05:32 AM
It's 2025 .... Still no preprovisioning available after 7 years - sigh!
