Prevent Multicast Traffic
alfredobosca
I have a big layer2 network and I would like to prevent multicast traffic. My goal would be avoid that all switches send multicast traffic. Would be possible avoid that the most of switches send multicast traffic?
Best regards,
Hello
No quite sure you should negate MC as a whole as various applications require it but it can be suppressed so it doesn't flood you network.
Igmp snooping can be applied to each vlan which can help control the distribution of MC traffic and not flood your network.
Possibly you could apply some port security to the switchports to limit MC traffic but whatever limit level you apply will also effect broadcast traffic hitting the port.
res
Paul
Kind Regards
Paul
