Private VLAN help
Brian M
Level 3
Level 3
Ok, this is my first private VLAN and maybe I am not getting the concept here but my isolated port cannot ping the IP address of the Primary VLAN interface.
How do you route Isolated ports? Do I have to configure a port as a L2 promiscuous and attach a router there?
Thanks!!
vlan 100
private-vlan primary
private-vlan association 101
vlan 101
private-vlan isolated
interface GigabitEthernet0/4
switchport private-vlan host-association 100 101
switchport mode private-vlan host
interface Vlan100
ip address 192.168.1.254 255.255.255.0
private-vlan mapping 101
end
nambi_gct
Level 6
Level 6
your private vlan config is perfect.I dont see any issues.are you able to ping the svi from the switch?
Istvan_Rabai
Level 11
Level 11
Hi Brian,
Your private-vlan config seems to me OK.
There may be some other reason why you can't ping your primary vlan interface.
Did you put the ip address of interface Vlan100 into your pc as the default gateway address?
Is interface Gig0/4 a layer2 port? Is it up up ?
Can you ping interface Vlan100 from a PC that connects directly into a port assigned to vlan 100?
Just some ideas for troubleshooting.
Cheers:
Istvan
GIG0/4 is a layer 2 port and it is up. I can only ping vlan 100 (from a PC in VLAN100)when I remove the private mapping from the SVI. The switch works fine in a standard VLAN setup but only works in private-vlan when I create a promiscuous port to a seperate router. Here is more info that hopefully helps.
Cisco IOS Software, C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(44)SE1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 07-Mar-08 00:10 by weiliu
Image text-base: 0x00003000, data-base: 0x01900000
HOUDMZ-01#sho int gig 0/4 swi
Switchport: Enabled
Administrative Mode: private-vlan host
Operational Mode: private-vlan host
Administrative Trunking Encapsulation: negotiate
Operational Trunking Encapsulation: native
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: 100 (DMZ_PRIMARY) 101 (DMZ_ISOLATED)
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan:
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
HOUDMZ-01#sho int private-vlan map
Interface Secondary VLAN Type
vlan100 101 isolated
vlan100 102 community
ahggg....as soon as I posted my last response I turned on IP Routing and voila.
This is kind of baffling though, even though I have no problem leaving IP Routing enabled should it work just fine without it being that I wasn't crossing VLAN boundries and just trying to ping an IP address within my own VLAN?
Who knows, maybe there's some secret logical madness Cisco has when it comes to private-vlans.
Thanks for all the help!!
