privilege level
I want to know privilege level of 0-15 in which , what no i give then its show me according to that level security.
sachinraja
Level 9
Level 9
Hi Mitang
Cisco has  3 priviledge levels by default: (from CCO):
privilege level 1 = non-privileged (prompt is router>), the default level for logging in
privilege level 15 = privileged (prompt is router#), the level after going into enable mode
privilege level 0 = seldom used, but includes 5 commands: disable, enable, exit, help, and logout
You can define commands based on the level of access needed on priv 2-14 .. for eg network mgmt team can be specificaly given priv 2 - with show int commands etc... you can view the level of a logged user using the "show priviledge" command...
Hope this helps.. all the best
Raj
Ganesh Hariharan
Hi ,
Check out the below link reagarding privilege levels in routers, Hope that helps to solve your query !!
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a00800949d5.shtml
Ganesh.H
