Problem at the Project
benr3933
Packet tracer project.
Hey guys im new here so go ez with me lol, Im about to do my Project but i got stuck on ssh (ez right? well i guess i did something wrong).
im able to ssh my routers (with no password some how, and i configured one, not sure why) but not the switch's (not any of them), oh one more thing, only vlan 10 able to enter by ssh\telnet so i mad acl there.
thats whats run at my switch's (i cant even ping from pc to switch vlan 1)
S0(config)#do show run
Building configuration...
Current configuration : 1600 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname S0
enable password 7 08701E1D5D
no ip domain-lookup
ip domain-name SnowN.com
username Sysadmin privilege 1 password 7 0878151B5C4854
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
switchport access vlan 20
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
ip address 192.168.10.222 255.255.255.0
access-list 10 permit 192.168.10.0 0.0.0.255
line con 0
password 7 08204E4D0D
login
line vty 0
access-class 10 in
login
transport input ssh
line vty 1 4
login
transport input ssh
line vty 5 15
login
end
26 Replies 26
the to-be-natted inside networks do not need to be directly connected to R1. Here is the config for R1 (file attached as well):
R1#sh run
Current configuration : 1137 bytes
version 15.4
hostname R1
ip cef
no ipv6 cef
username SysAdmin password 0 995511
interface GigabitEthernet0/0/0
ip address 172.31.0.253 255.255.0.0
ip ospf 10 area 0
--> ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/0/1
ip address 209.165.200.253 255.255.255.0
ip ospf 10 area 0
--> ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router ospf 10
log-adjacency-changes
--> ip nat inside source list 1 interface GigabitEthernet0/0/1 overload
ip classless
ip flow-export version 9
--> access-list 1 permit 192.168.10.0 0.0.0.255
--> access-list 1 permit 192.168.20.0 0.0.0.255
no cdp run
line con 0
line aux 0
line vty 0
access-class 10 in
login
transport input ssh
line vty 1 4
login
transport input ssh
end
can i choose 80.0.0.1 as a outside ip? if ye how? (i know its supposed to be pool :D)
yes indeed, you need a pool. Everything will be translated to 80.0.0.1:
--> ip nat pool NAT_OUT 80.0.0.1 80.0.0.1 netmask 255.255.255.0
--> no ip nat inside source list 1 interface GigabitEthernet0/0/1 overload
--> ip nat inside source list 1 pool NAT_OUT add-route
Georg something went wrong, im loseing it xD
i did at router 1 what u said but now i have no communicate with outside... no ping no nothing
can u check it? tell me what i did wrong? (vlans cant go out farther then R1)
its diff folder coz i made more things inside :S
you need to add a static route on R2 for the new network 80.0.0.0/24:
R2(config)#ip route 80.0.0.0 255.255.255.0 GigabitEthernet 0/0/0
oooofff its working but i cant see at show ip nat translations the ip changing from 192.168.10.1 for example to 80.0.0.1 (i tried to ping the web, tried to http it, still no translation there)
any idea?
I am pinging from 192.168.1.10 to 172.19.0.100, here is the (partial) output on R2:
R2#sh ip nat translations
icmp 80.0.0.1:26 192.168.10.1:26 172.19.0.100:26 172.19.0.100:26
icmp 80.0.0.1:27 192.168.10.1:27 172.19.0.100:27 172.19.0.100:27
icmp 80.0.0.1:28 192.168.10.1:28 172.19.0.100:28 172.19.0.100:28
icmp 80.0.0.1:29 192.168.10.1:29 172.19.0.100:29 172.19.0.100:29
icmp 80.0.0.1:30 192.168.10.1:30 172.19.0.100:30 172.19.0.100:30
Make sure you have the correct file (attached) opened.
here download the new zip, i did the same as u ( i think) at router one i set the commands at R1
--> access-list 1 permit 192.168.0.0 0.0.255.255
and i have nothing inside the ip nat translations
did i missed something again T-T?
and how do i know that i wont get the same ip as the router at outside? should i make a pool for that?
benr3933
hehe well u doing great.
thanks
btw one more question, as u can see there is a switch the most left side plug in to dns.
if i want to ssh him what do i do? i mean the same vlan 10? what ip address? what default gateway? (coz he is at diff network)
