Problem at the Project
benr3933
Community Member
Packet tracer project.
Hey guys im new here so go ez with me lol, Im about to do my Project but i got stuck on ssh (ez right? well i guess i did something wrong).
im able to ssh my routers (with no password some how, and i configured one, not sure why) but not the switch's (not any of them), oh one more thing, only vlan 10 able to enter by ssh\telnet so i mad acl there.
thats whats run at my switch's (i cant even ping from pc to switch vlan 1)
S0(config)#do show run
Building configuration...
Current configuration : 1600 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname S0
enable password 7 08701E1D5D
no ip domain-lookup
ip domain-name SnowN.com
username Sysadmin privilege 1 password 7 0878151B5C4854
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
switchport access vlan 20
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
ip address 192.168.10.222 255.255.255.0
access-list 10 permit 192.168.10.0 0.0.0.255
line con 0
password 7 08204E4D0D
login
line vty 0
access-class 10 in
login
transport input ssh
line vty 1 4
login
transport input ssh
line vty 5 15
login
end
בבקשה
Sorry for my enthusiasm...I am in the process of learning Hebrew...
26 Replies 26
Georg Pauwen
post the zipped Packet Tracer project (.pkt) file.
U need to open the packet tracer, then open the file, or else u wont be able to see the project (but i guess u already know that hehe)
the file you sent is empty...?
no, u need to open the program packet tracer, not the packet that i send, when u inside the packet tracer program click file>open and choose the packet tracer i sended.
then its should be working, and u will be able to see everything that iv done
got it. What is the password for the switch ? Looks like you need to change the configuration of the switch like below:
interface Vlan 1
no ip address
interface Vlan10
ip default-gateway 192.168.10.254
oh right password for user its abcd and enable its 1234
when u done can u tell me exactly what u did?
Hello, shalom,
all your PCs are on other than the default Vlan (1). The switch has an IP address from Vlan 10, so assigning the IP address to the Vlan 1 interface won't work. As stated in the previous post, you need to create a Vlan 10 interface and assign the IP address to that interface. You also need to add an ip default gateway with the IP address of the Vlan 10 subinterface.
That said, if you want to reach the other switches as well, configure the same on these switches (with a different IP address for the Vlan 10 interface, obviously).
Find attached the revised, working file (saved in version 7.3.1.).
TY so much!! u saved me hehe
really thank you so much.
בבקשה
btw one more question, as u can see there is a switch the most left side plug in to dns.
if i want to ssh him what do i do? i mean the same vlan 10? what ip address? what default gateway? (coz he is at diff network)
you could use any Vlan (10 or 20), but is is good practice to keep the management IP addresses in the same Vlan. I have added a Vlan 10 interface and IP address (and default gateway) to the two remaining switches, file attached.
Georg i have one more prob, i have no idea ho to use nat (pat) from 172.31.0.0/16 to LAN2... can u tell me whats the command? i think it should be at router 1 which there the ip become inside or outside right? but what next?
add the lines marked in bold to R0 (working, revised file attached):
R0#sh run
Current configuration : 1655 bytes
version 15.4
hostname R0
ip dhcp pool R1-LAN
network 192.168.10.0 255.255.255.0
default-router 192.168.10.254
dns-server 172.19.0.100
ip dhcp pool R2-LAN
network 192.168.20.0 255.255.255.0
default-router 192.168.20.254
ip cef
no ipv6 cef
username SysAdmin password 7 0878151B5C4854
interface GigabitEthernet0/0/0
no ip address
ip ospf 10 area 0
duplex auto
speed auto
interface GigabitEthernet0/0/0.10
encapsulation dot1Q 10
ip address 192.168.10.254 255.255.255.0
ip ospf 10 area 0
--> ip nat inside
interface GigabitEthernet0/0/0.20
encapsulation dot1Q 20
ip address 192.168.20.254 255.255.255.0
ip ospf 10 area 0
--> ip nat inside
interface GigabitEthernet0/0/1
ip address 172.31.0.254 255.255.0.0
ip ospf 10 area 0
--> ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router ospf 10
log-adjacency-changes
--> ip nat inside source list 1 interface GigabitEthernet0/0/1 overload
ip classless
ip flow-export version 9
--> access-list 1 permit 192.168.10.0 0.0.0.255
--> access-list 1 permit 192.168.20.0 0.0.0.255
no cdp run
line con 0
login
line aux 0
line vty 0
access-class 10 in
login
transport input ssh
line vty 1 4
login
transport input ssh
end
it must to be at router 1 at my project, thats why it makes me shutdown lol... router 1 has only 172.31.... and 209.165....
so at my project they want the inside and outside to be from 172.31.... thats mean all what u type i need to do it at r1 but there is no sub interface for network 192.168.... so what to do?
