Problem Connecting to Internet from LAN Behind 2811 VDSL
Adam_S
Hi All,
Was hoping someone could help me here. I'm trying to connect a Netcomm (NF8AC VDSL) modem to a cisco 2811 and route internet through it but not having much luck with it. This is my first post so i apologise if something is amiss.
I've connected the netcomm to FA0/0 (80.80.80.1) and assigned it IP 80.80.80.2 connected to ethernet 4. I can ping from the modem to Fa0/0 and vice versa, but I cannot ping from my internal subnets to the netcomm (80.80.80.2).
I've tried RIP routing (which worked on a previous huawei modem). No luck
I've tried adding a static route pointing to to the netcomm (ip route 0.0.0.0 0.0.0.0 fa 0/0). No luck.
If I add static routes to the netcomm i can gain access to the internal subnets and even telnet to cisco router, but still no internet access.
I've attached a basic diagram and the config is in thread.
Amel#show ip route
Gateway of last resort is not set
     80.0.0.0/24 is subnetted, 1 subnets
C       80.80.80.0 is directly connected, FastEthernet0/0
     172.17.0.0/24 is subnetted, 1 subnets
C       172.17.0.0 is directly connected, Vlan17
     172.16.0.0/24 is subnetted, 1 subnets
C       172.16.0.0 is directly connected, Vlan16
     10.0.0.0/8 is variably subnetted, 5 subnets, 2 masks
C       10.12.0.0/24 is directly connected, Vlan12
C       10.112.0.0/24 is directly connected, Vlan112
C       10.212.0.0/24 is directly connected, Vlan212
C       10.213.0.0/24 is directly connected, Vlan213
C       10.255.255.255/32 is directly connected, Loopback0
C    192.168.0.0/24 is directly connected, Vlan10
Amel#show run
Building configuration...
Current configuration : 8267 bytes
version 12.4
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
hostname Amel
boot-start-marker
boot system flash:c2800nm-advipservicesk9-mz.124-15.T9.bin
boot-end-marker
logging buffered 4096 informational
enable secret 5 $1$ZFe8$g4l2RoRNxgxEw.lD.QLYY0
no aaa new-model
clock timezone AEST 10
clock summer-time AEDT recurring last Sun Oct 2:00 last Sun Mar 3:00
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1 192.168.0.100
ip dhcp excluded-address 10.212.0.1 10.212.0.100
ip dhcp excluded-address 10.12.0.1 10.12.0.100
ip dhcp excluded-address 10.112.0.1 10.112.0.100
ip dhcp excluded-address 10.213.0.1 10.213.0.100
ip dhcp excluded-address 172.16.0.1 172.16.0.100
ip dhcp excluded-address 192.168.20.1 192.168.20.100
ip dhcp pool VLAN10_MANAGEMENT
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   lease 24
ip dhcp pool VLAN212_W_DATA
   network 10.212.0.0 255.255.255.0
   default-router 10.212.0.1
   dns-server 203.12.160.35
   lease 24
ip dhcp pool VLAN213_Wireless_Voice
   network 10.213.0.0 255.255.255.0
   default-router 10.213.0.1
   lease 24
ip dhcp pool VLAN12_DATA
   network 10.12.0.0 255.255.255.0
   default-router 10.12.0.1
   lease 24
ip dhcp pool VLAN16_WIRELESS_N
   network 172.16.0.0 255.255.255.0
   default-router 172.16.0.1
   lease 24
ip dhcp pool VLAN112_Voice
   network 10.112.0.0 255.255.255.0
   default-router 10.112.0.1
   lease 24
no ip domain lookup
ip name-server 8.8.8.8
ip multicast-routing
voice-card 0
 no dspfarm
vtp domain home
vtp mode transparent
archive
 log config
  hidekeys
vlan 10
 name Managemet
vlan 12
 name DataVlan
vlan 16
 name WIRELESS_N
vlan 17
 name Home_Automation
vlan 20
 name Guest
vlan 112
 name VoiceVlan
vlan 212
 name Wireless
vlan 213
 name WirelessPhones
interface Loopback0
 ip address 10.255.255.255 255.255.255.255
 ip broadcast-address 0.0.0.0
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 10.255.255.255
interface FastEthernet0/0
 description Internet
 ip address 80.80.80.1 255.255.255.0
 ip nat outside
 ip virtual-reassembly
 duplex full
 speed 100
interface FastEthernet0/1
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/1/0
 switchport trunk native vlan 10
 switchport mode trunk
 duplex full
 speed 100
 spanning-tree portfast
interface FastEthernet0/1/1
 duplex full
 speed 100
interface FastEthernet0/1/2
 description AP1
 duplex full
 speed 100
interface FastEthernet0/1/3
 switchport access vlan 16
 duplex full
 speed 100
interface FastEthernet0/1/4
 description Alarm
 switchport access vlan 17
 duplex full
 speed 100
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
 duplex full
 speed 100
interface FastEthernet0/1/8
 duplex full
 speed 100
interface Serial0/3/0
 no ip address
 encapsulation frame-relay
 clock rate 2000000
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 description Management
 ip address 192.168.0.1 255.255.255.0
interface Vlan12
 description Data
 ip address 10.12.0.1 255.255.255.0
 ip nat inside
interface Vlan16
 description Wirless_N
 ip address 172.16.0.1 255.255.255.0
 ip helper-address 10.12.0.2
 ip directed-broadcast
interface Vlan17
 description Home_Automation
 ip address 172.17.0.1 255.255.255.0
 ip nat inside
interface Vlan112
 description Voice
 ip address 10.112.0.1 255.255.255.0
interface Vlan212
 description Wireless_G
 ip address 10.212.0.1 255.255.255.0
interface Vlan213
 description Wireless_Voice
 ip address 10.213.0.1 255.255.255.0
router rip
 version 2
 network 10.0.0.0
 network 80.0.0.0
 network 172.16.0.0
 network 172.17.0.0
 network 192.168.0.0
 no auto-summary
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source static tcp 10.12.0.2 443 80.80.80.1 443 extendable
ip nat inside source static udp 10.12.0.2 443 80.80.80.1 443 extendable
ip nat inside source static tcp 10.12.0.2 8000 80.80.80.1 8000 extendable
ip nat inside source static udp 10.12.0.2 8000 80.80.80.1 8000 extendable
ip nat inside source static tcp 10.12.0.2 8001 80.80.80.1 8001 extendable
ip nat inside source static udp 10.12.0.2 8001 80.80.80.1 8001 extendable
ip nat inside source static tcp 172.17.0.2 10000 80.80.80.1 10000 extendable
ip nat inside source static udp 172.17.0.2 10000 80.80.80.1 10000 extendable
ip nat inside source static tcp 172.17.0.2 10001 80.80.80.1 10001 extendable
ip nat inside source static udp 172.17.0.2 10001 80.80.80.1 10001 extendable
ip nat inside source static tcp 10.12.0.2 55555 80.80.80.1 55555 extendable
ip nat inside source static udp 10.12.0.2 55555 80.80.80.1 55555 extendable
tftp-server flash:/c7921/APPS-1.0.4.SBN alias APPS-1.0.4.SBN
tftp-server flash:/c7921/CP7921G-1.0.4.LOADS alias CP7921G-1.0.4.LOADS
tftp-server flash:/c7921/GUI-1.0.4.SBN alias GUI-1.0.4.SBN
tftp-server flash:/c7921/SYS-1.0.4.SBN alias SYS-1.0.4.SBN
tftp-server flash:/c7921/TNUX-1.0.4.SBN alias TNUX-1.0.4.SBN
tftp-server flash:/c7921/TNUXR-1.0.4.SBN alias TNUXR-1.0.4.SBN
tftp-server flash:/c7921/WLAN-1.0.4.SBN alias WLAN-1.0.4.SBN
tftp-server flash:/c7911new/c7911/apps11.8-3-2-27.sbn alias apps11.8-3-2-27.sbn
tftp-server flash:/c7911new/c7911/cnu11.8-3-2-27.sbn alias cnu11.8-3-2-27.sbn
tftp-server flash:/c7911new/c7911/cvm11sccp.8-3-2-27.sbn alias cvm11sccp.8-3-2-27.sbn
tftp-server flash:/c7911new/c7911/dsp11.8-3-2-27.sbn alias dsp11.8-3-2-27.sbn
tftp-server flash:/c7911new/c7911/jar11sccp.8-3-2-27.sbn alias jar11sccp.8-3-2-27.sbn
tftp-server flash:/c7911new/c7911/SCCP11.8-3-3S.loads alias SCCP11.8-3-3S.loads
tftp-server flash:/c7911new/c7911/term06.default.loads alias term06.default.loads
tftp-server flash:/c7911new/c7911/term11.default.loads alias term11.default.loads
control-plane
voice-port 0/2/0
voice-port 0/2/1
ccm-manager redundant-host 10.12.0.21
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold bind Loopback0
ccm-manager config server 10.12.0.21
ccm-manager config
mgcp
mgcp call-agent 10.12.0.25 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
mgcp behavior g729-variants static-pt
mgcp profile default
dial-peer voice 999020 pots
 service mgcpapp
 port 0/2/0
dial-peer voice 999021 pots
 service mgcpapp
 port 0/2/1
dial-peer voice 999030 pots
 service mgcpapp
dial-peer voice 1 voip
 destination-pattern 10924
 session target ipv4:10.255.255.255
call-manager-fallback
 max-conferences 8 gain -6
 transfer-system full-consult
 ip source-address 10.255.255.255 port 2000
 max-ephones 5
 max-dn 5
line con 0
line aux 0
line vty 0 4
 exec-timeout 0 0
 password 7 10620C0A111606
 login
line vty 5
 exec-timeout 0 0
 password 7 00071A150754
 login
scheduler allocate 20000 1000
ntp clock-period 17180095
ntp update-calendar
ntp server 216.239.38.15
end
No problem, just mark this post as helpful and solved ;)
cheers,
Seb.
Seb Rupik
Hi Adam,
You are missing a default route on your router:
ip route 0.0.0.0 0.0.0.0 80.80.80.2
However it looks to me like you NAT setup is also only partialy configured.
Remove your existing ip nat commands, and use the following:
ip access-list NAT-ACL
  permit ip 10.12.0.0 0.0.0.255
  permit ip 172.17.0.0 0.0.0.255
ip nat inside source list NAT-ACL interface fa0/0 overload
The contents of the NAT-ACL is based on the interfaces which you have marked as ip nat inside . Add to this ACL if you want to NAT more interfaces (and add the ip nat inside command too). this will ensure that all NAT'd traffic has a global-outside address of 80.80.80.1 (fa0/0) which your Netcomm has a directly attached interface too and will know how to return packets to.
As a sainity check please provide the output of :
sh ip nat statistics
cheers,
Seb.
Thank you x Inifinity. I was going out of my mind trying to get this going.
YOU SIR DESERVE A RAISE!
After tweaking the ACL you suggested and correcting my DNS. everything is
working.
cheers,
Seb.
