Problem creating switch virtual link
Colin Higgins
Level 7
Level 7
I have two brand-new Catalyst 4500X switches running cat4500e-UNIVERSALK9-M. The switch has GLC-T 10Gbs copper SFPs in it. All the ports are set to "switchport"
I am trying to crate a VSS pair, but I cannot bundle interfaces T2/7 & 8. I am getting error:
Te2/8 is not compatible with Po10 and will be suspended (trunk mode of Te2/8 is dynamic, Po10 is trunk)
I followed the procedure as follows
Switch1:
switch virtual domain 5
switch 1
switch 1 priority 110
switch 2 priority 100
interface port-channel 10
switchport
switch virtual link 1
no shut
interface range ten 2/7 & 8
channel-group 10 mode on
Switch 2:
switch 2
interface port-channel 20
switchport
switch virtual link 2
no shut
interface range ten 2/7 - 8
channel-group 20 mode on
If I look at the config on switch 1, it looks correct
interface TenGigabitEthernet2/7
 switchport mode trunk
 switchport nonegotiate
 no lldp transmit
 no lldp receive
 no cdp enable
 service-policy output VSL-Queuing-Policy
interface TenGigabitEthernet2/8
 no lldp transmit
 no lldp receive
 no cdp enable
But po10 is down (waiting to aggregate)
Is there something I am missing here? What am I doing wrong?
Colin Higgins
Level 7
Level 7
I can answer my own question here
the error is "transient" and goes away after the conversion process is complete. Po10 in this instance will not come up until conversion, despite what it says in the official documentation
Colin Higgins
Level 7
Level 7
