Problem with 10G Card on Cat 6513
Dao Quynh
Hi all,
I have just buy a 10G card for Cat 6513, these are information:
PDCMSFC-1>sh module
Mod Ports Card Type                              Model              Serial No.
  2   16  SFM-capable 16 port 1000mb GBIC        WS-X6516A-GBIC     SAL08373Z37
  7    2  Supervisor Engine 720 (Active)         WS-SUP720-BASE     SAD08330322
Mod Sub-Module                  Model              Serial        Hw     Status
  7 Policy Feature Card 3       WS-F6K-PFC3A       SAD083207AL   2.4    Ok
  7 MSFC3 Daughterboard         WS-SUP720          SAD0832037Y   2.3    Ok
About card: WS-X6716-10G-3C
When I install this card on Cat 6513, has a message: " fan tray no support"
Please help me solve this problem...
Thank all,
Quynh
5 Replies 5
mfurnival
Level 4
Level 4
Check out this page: http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Chassis_Installation/Cat6500/0dpwrht.html
The installation of the WS-X6716-10G-3C blade requires additional cooling hence the message about the fan tray.
Thank mfurnival,
But, What do I do to solve this problem: buy fan tray, buy module Power, ...
It may be you need to use the high speed fan tray. Can you post the output of the show environment cooling command? This will tell you the cooling capability of the current fan tray and cooling requirement of the modules installed.
Hi steve-fuller,
This is result:
how environment status all ------------------
backplane:
  operating clock count: 2
  operating VTT count: 3
fan-tray 1:
  fan-tray 1 type: WS-C6K-13SLT-FAN2
  fan-tray 1 version: 2
  fan-tray 1 fan-fail: OK
VTT 1:
  VTT 1 OK: OK
  VTT 1 outlet temperature: 25C
Hi all,
thank for your support
I did "shutdown" the chassis and reinstall again then Cat6513 see the 10G card.
