Problem with 2960-TTL
brandon1982
Dear all,
would like to know if anyone of u experience the following problem.
i'm have 2 units of 2960TTL 24 at my office. and each of it has a port being disable.
when i type sh interface status.
there's an err-disable at the status.
i cant seem to enable it inside CNA.
the error msg in CNA is that
a loopback has been detected and it recommended to run smartport.
both port were initially plugged in with a linksys which, which is no longer connected now.
i've tried to remove configuration on the respective port and the error is still there. should i reset the configuration to factory default?
or the port is faulty?
please advice. thank you.
2 Accepted Solutions
sourabhagarwal
Level 4
Level 4
It seems that port is in err-disable state. To recover it from that state, you need to "shut" and then "no shut" the port.
int fa0/1
shutdown
no shutdown
HTH, rate if it does ...
A port may be put into errordisable state for a lot of reasons ( loopback detected, UDLD, link-flap, PAgp flap, BPDU guard etc)
There are 2 ways to recover from this state.
Either do a shut , no shut on the interface or you should have the following command configured globally
errdisable recovery cause
What you should be really looking at is the cause which is forcing the ports to go errordisable...time to relook at your design so that the incident does not repeat
Narayan
8 Replies 8
sourabhagarwal
Level 4
Level 4
int fa0/1
shutdown
no shutdown
let me try.
will get back to you asap.
thanks for replying.
hi there
manage to solve the problem.
thanx alot.
really appreciate it.
brandon.
vijayasankar
Level 4
Level 4
Can you perform a shut and no shut on these ports.
-VJ
let me try.
Narayan
hi there
thanx alot.
but wat would likely be the cause of this?
brandon.
Should tell you in the logs why it err-disabled the port .
