Problem with 3560 switch
serenity001
hi
i have a a switch with a corupted image on it, i did the steps of sending a new image through the xmodem ..
but i booted from the new image i got this msg
Loading "c3560-ipbasek9-mz.122-25.SED1.bin"...c3560-ipbasek9-mz.122-25.SED1.bin: no such device
Error loading "c3560-ipbasek9-mz.122-25.SED1.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c3560-ipbasek9-mz.122-35.SE5.bin"...@@@@@@@@@@@@@
i don't know why its looking for the old ios ...
also when i reloded the switch and get the switch# prompt, i did show runn i noteced a command on some ports which i didn't put ( i have configured the vlans and other stuff butt didn't configuer this vlan)
switchport trunk pruning vlan 2-941,943-1001
please see the attached for more information
9 Replies 9
lamav
Level 8
Level 8
Hi:
Can you execute the following commands and post the output?
sh ver
sh flash
sh boot
dir /all
VL
hi lamav
thx for your response, the attached is what you have requested
regards
hi ...
any update ??
you must enter config mode and then
issue
boot system flash:/your_new_image.
write te config and then reload.
rate if it helps
regards
thx ,
will do it then will give you the feed back
but also after rebooting, and issuing show runn
i see this command under some of the interfaces
and i didn't write tis command ever..
regards
I think you are rely on an old config.
but you can also disable pruning.
Rg
thank you
but still i have a problem :(
see this
interface FastEthernet0/7
switchport access vlan 44
switchport trunk allowed vlan 1-4077,4079-4094
switchport mode access
i didn't issue the trunk command ... is it a bug??
any update >??
I think that they arent issued themselves.
disable this config.
It might have be an error or bug if not an security issue
