Problem with Cisco 2911 configuration
SteveHoyle
I have a Cisco 2911 plugged into an HP Switch which also runs fiber to another HP Switch.  Both of these switches run to multiple computers.  There are two networks but only one router.  I can ping anywhere outside from the router and also to any computer.  I can ping the router from one network but not the other.  I can ping one network from the computer but not the other way around.  I can't ping to the ISP's DNS or any website from any computer.  Can someone please help me with this?
#interface GigabitEthernet0/0
if)#ip nat outside
#interface GigabitEthernet0/1
if)#ip nat inside
#interface GigabitEthernet0/2
if)#ip nat inside
(config)#ip nat pool POOLNAME 68.15.57.204  68.15.57.204 netmask 255.255.255.192
#ip access-list extended xyz
nac1)#permit ip 172.18.113.0 0.0.0.255
nac1)#permit ip 172.18.112.0 0.0.0.255
config)#ip nat inside source list xyz pool POOLNAME overload
#show ip nat translations (when you are finished)
17 Replies 17
John Blakley
It sounds like it's a natting issue. Can you post your configuration? Being that you have 2 networks, are you using vlans?
HTH, John *** Please rate all useful posts ***
I'm currently not using VLANS.
Here is the configurations.
Building configuration...
Current configuration : 1379 bytes
! No configuration change since last restart
version 15.0
service password-encryption
hostname ovrbrkrouter
boot-start-marker
boot config flash0:router-config
boot-end-marker
security authentication failure rate 5 log
enable secret 5 $1$Tl4e$JEiYtibckmluxVI.Ivsvo.
enable password 7 15010E0D557A7A7429253021
no aaa new-model
no ipv6 cef
ip source-route
no ip routing
no ip cef
ip name-server 208.67.222.222
ip name-server 208.67.220.220
login block-for 120 attempts 5 within 30
license udi pid CISCO2911/K9 sn FCZ150471ZA
redundancy
ip address 68.15.57.204 255.255.255.192
no ip route-cache
duplex auto
speed auto
no mop enabled
ip address 172.18.112.1 255.255.255.0
no ip route-cache
duplex auto
speed auto
no mop enabled
ip address 172.18.113.1 255.255.255.0
no ip route-cache
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 20 0
password 7 00171607550B5A560E37494D
login
line aux 0
line vty 0 4
password 7 1404170A5D547B7B253E3636
login
scheduler allocate 20000 1000
end
let your traffic know where to route out aswell..
ip route 0.0.0.0 0.0.0.0 x.x.x.x
and also apply your acl's and natting inside/outside
I hope it helps..
Best regards,
Willy
Warren.Arthur
I'm guessing your computers have static IP addresses on both networks? because you dont have dhcp enabled on the router.
I'm actually using Server 08R2 to run a DHCP Server.  Do I need to tell the router that I have an external DHCP Server?
I'm going to add NAT and see if I'm able to connect.  I'm not sure if I'll get to that tonight or tomorrow.  Thanks for the advice.  I'll let you know how it goes.
ok hope it works out for you!
Warren.Arthur
No not necessary, you need to enable NAT because you are not able to get outside your network to the internet.
if)#ip nat outside
if)#ip nat inside
if)#ip nat inside
Before I save this to the startup Config I wanted to make sure the configuration looks correct.  Can you take a look?
ip nat outside
ip virtual-reassembly
no ip route-cache
duplex auto
speed auto
no mop enabled
ip nat inside
no ip route-cache
duplex auto
speed auto
no mop enabled
ip nat inside
no ip route-cache
duplex auto
speed auto
no ip http server
permit ip 172.18.112.0 0.0.0.255 172.18.113.0 0.0.0.255
control-plane
line con 0
exec-timeout 20 0
login
line aux 0
line vty 0 4
login
end
Warren.Arthur
add the
#ip route 0.0.0.0 0.0.0.0 68.15.57.204
Test to make sure before you save your config files
When I try to add #ip route 0.0.0.0 0.0.0.0 68.15.57.204 I get this error.
%Invalid next hop address (it's this router)
try to route to your isp dns or gateway......
ip route 0.0.0.0    0.0.0.0   (DNS ip ADD) or (ISP GATEWAY)
WILLY
Thanks,  I'm going to try that.
