Problem with InterVLAN routing
MaciejPiechota
Frequent Visitor
Frequent Visitor
Dear All,
Two weeks ago we replaced our switches to new CBS350 devices and we segmented the network into several VLANs. As network core we're using 4 devices (2x CBS350-24XT and 2x CBS350-XTS) and these switches are used for InterVLAN routing.
Unfortunately, after these changes, starting routing between VLANs on hosts sometimes takes a very long time (up to several minutes) even though the devices almost immediately receive an IP address from DHCP server and don't have any problems with connecting to hosts within the their VLAN.
Example below - my computer located in one VLAN easily pings a host that is also in this VLAN, but there is no connection both to the host from other VLAN and IP address of first's VLAN gateway (core switch).
I also noticed that when there's no communication between VLANs and with the core switch, the entry with the gateway address is not present in the ARP table on my computer (as if there was some MAC address conflict in the network?). For the test, I added a manual entry in the ARP table of my computer and when I have this setting, there are no problems (as if the core switches had a problem with broadcast their MAC address on the network?)
Of course, core switches have an IP address set in each VLAN and there's entry for every VLAN in IPv4 Forwarding Table.
Does someone had similar issue and can help me in that case? Many thanks in advance for every answer!
BR
acampbell
On your inter vlan routing switch can you ensure that you have enabled IP V4 routing in the Vlan interface page.
Regards, Alex. Please rate useful posts.
Hi Alex,
thanks for your reply! Can you specify where can I find this option? I can't see it neither in VLAN Management or IPv4 Configuration.
@MaciejPiechota hi, check if your IPV4 routing enabled.
IPV4 Configuration > IPV4 interface > IPV4 Routing. enable
Good luck
KB
Hi @Kasun Bandara,
thanks for answer! IPv4 routing is enabled.
