Problem with my project (2 switches) (1 router)
st2022350
Hello everyone,
First and foremost, I apologize for my lack of knowledge in the field, as I am a relatively new student in the networking world with limited experience.
Currently, I am working on a school project in which I need to provide private and internet services to three different VLANs.
The classroom computers are configured to operate on a switch with the network 192.168.36.0/24.
My router is connected to the classroom switch to ensure that the class computers can access the settings of the devices I am working with.
The connection between my router and the switch is made through optical fiber.
Based on this setup, I have three VLANs that are working to provide Public services, private services, and network resources.
- VLAN 10: Private Services
- VLAN 20: Public Services
- VLAN 30: Network Administration
The issue is that my router can ping 8.8.8.8, but my switch cannot.
Additionally, I have tried to configure DHCPv4 for VLAN 1 networks, but it is not functioning.
I can access the switch and router through PuTTY:
- Router: 192.168.36.17
- Switch: 10.10.37.254
Honestly, I would appreciate it if someone could review the configuration of both devices, identify errors (which I'm sure there are many), and assist me in correcting them with the necessary commands.
Thank you very much to anyone who has taken the time to read this.
Router Config:
Router-G7#show conf
Router-G7#show configuration
Using 2379 out of 262136 bytes
! Last configuration change at 13:18:28 UTC Mon Jan 22 2024 by stucom8
version 15.4
service password-encryption
hostname Router-G7
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXXXX
no aaa new-model
ip dhcp excluded-address 10.10.10.1 10.10.10.127
ip dhcp excluded-address 10.10.17.1 10.10.17.127
ip dhcp pool LAN-Usuarios
 network 10.10.17.128 255.255.255.128
 default-router 10.10.17.1
 dns-server 172.16.2.10
ip domain name stucom8
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO1921/K9 sn FCZ19216002
username stucom8 secret 5 $XXXXXXXX
username userstucom8 privilege 15 password XXXXXXXXXXXX
username cisco password 7 XXXXXXXXXX
redundancy
ip ssh version 2
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description Interfaz 0/0 - Conexion aula36
 ip address 192.168.36.17 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/0.10
 shutdown
interface GigabitEthernet0/0.20
 shutdown
interface GigabitEthernet0/0.30
 shutdown
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0/0
 no ip address
interface GigabitEthernet0/0/0.10
 encapsulation dot1Q 10
 ip address 10.10.17.2 255.255.255.0
interface GigabitEthernet0/0/0.20
 encapsulation dot1Q 20
 ip address 10.10.27.2 255.255.255.0
interface GigabitEthernet0/0/0.30
 encapsulation dot1Q 30
 ip address 10.10.37.2 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.36.1
control-plane
line con 0
 exec-timeout 5 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
scheduler allocate 20000 1000
end
SWITCH CONFIG:
Switch-G7>ena
Password:
Switch-G7#show confi
Switch-G7#show configuration
Using 3005 out of 65536 bytes
version 12.2
no service pad
hostname Switch-G7
boot-start-marker
boot-end-marker
enable secret 5 $XXXXXXXXX
username stucom8 secret 5 $XXXXXXXXXX
no aaa new-model
system mtu routing 1500
authentication mac-move permit
ip subnet-zero
ip domain-name G8.com
crypto pki trustpoint TP-self-signed-811728896
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-811728896
revocation-check none
rsakeypair TP-self-signed-811728896
crypto pki certificate chain TP-self-signed-811728896
certificate self-signed 01 nvram:IOS-Self-Sig#3638.cer
port-channel load-balance src-dst-ip
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
ip ssh version 2
interface Port-channel1
description ESXi_Host7
switchport access vlan 20
switchport mode access
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
switchport access vlan 30
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
channel-group 1 mode on
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
switchport access vlan 10
interface GigabitEthernet0/20
interface GigabitEthernet0/21
description Interfaz 21 - Conexion Fibra
switchport trunk allowed vlan 10,20,30
switchport mode trunk
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface Vlan1
no ip address
no ip route-cache
interface Vlan10
no ip address
no ip route-cache
interface Vlan20
no ip address
no ip route-cache
interface Vlan30
ip address 10.10.37.254 255.255.255.0
no ip route-cache
ip default-gateway 10.10.37.2
ip http server
ip sla enable reaction-alerts
line con 0
exec-timeout 5 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
end
M02@rt37
Hello @st2022350
When you ping from router 8.8.8.8 your router use thé source IP 192.168.36.17. So, aula36 router perform NAT since packet IP source IS in the range 192.168.36.0/24.
You need to perform NAT on your Router for others subnets. NAT overload on int gig0/0.
Best regards
8 Replies 8
you need in router config NAT for mgmt VLAN of SW
and check RIB of router do you see VLAN mgmt of SW or not ?
MHM
M02@rt37
Hello @st2022350
Best regards
So the config I should do due to have internet in my vlans in my switch is something like this?
ip nat outside
ip nat inside
ip nat inside
ip nat inside
ip nat inside source list 1 interface GigabitEthernet0/0 overload
access-list 1 permit 10.10.17.0 0.0.0.255
access-list 1 permit 10.10.27.0 0.0.0.255
access-list 1 permit 10.10.37.0 0.0.0.255
access-list 1 permit 10.10.37.0 0.0.0.255 <- this subnet of vlan of SW
What othet subnet you add to NAT list ?
Is it for host ?
If Yes then your config correct
MHM
Thanks for the help! Finally, after following the configuration advice you provided, it worked.
The issue was with the main router, which was unable to send data to my interfaces.
Friend you are so welcome
Have a nice day
MHM
Hello @st2022350 ,
I don't see any errors in your configurations, but like @MHM Cisco World mentioned you are missing the configuration for NAT/PAT for vlan 30, 10.10.37.0/24, in order to enable this vlan, management IP of the switch included, to access the outside world.
Here is a document that can help you configure this on your router: https://www.cisco.com/c/en/us/support/docs/long-reach-ethernet-lre-digital-subscriber-line-xdsl/asymmetric-digital-subscriber-line-adsl/12905-827spat.html
Regards, LG
*** Please Rate All Helpful Responses ***
there are numerous issues with your configs. I marked the changes in bold.
Router-G7#
version 15.4
hostname Router-G7
boot-start-marker
boot-end-marker
enable secret 5 $1$bjme$V9XR8FCJo86Jfcyjyf0221
no aaa new-model
ip dhcp excluded-address 10.10.27.1 10.10.17.127
ip dhcp excluded-address 10.10.37.1 10.10.17.127
ip dhcp excluded-address 10.10.37.254
ip dhcp pool LAN10-Usuarios
network 10.10.17.0 255.255.255.0
default-router 10.10.17.2
ip dhcp pool LAN20-Usuarios
network 10.10.27.0 255.255.255.0
default-router 10.10.27.2
ip dhcp pool LAN30-Usuarios
default-router 10.10.37.2
ip cef
no ipv6 cef
cts logging verbose
username stucom8 secret 5 $1$ci9l$URht.M6qWp8tSNXY0fz930
username userstucom8 privilege 15 password 7 001707130754065E
username cisco password 7 14141B180F0B
redundancy
ip ssh version 2
no ip address
shutdown
ip nat outside
duplex auto
speed auto
shutdown
shutdown
shutdown
no ip address
duplex auto
speed auto
no ip address
ip nat inside
ip nat inside
ip nat inside
no ip http server
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
control-plane
line con 0
exec-timeout 5 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
end
SWITCH CONFIG:
Switch-G7>ena
Password:
version 12.2
no service pad
hostname Switch-G7
boot-start-marker
boot-end-marker
enable secret 5 $1$njYU$UMH9JH3SYNh.hblG3z6pX.
username stucom8 secret 5 $1$x6h2$S8EKaEo15nAs2vgEkO6C81
no aaa new-model
ip subnet-zero
ip ssh version 2
interface Vlan1
no ip address
no ip route-cache
--> no interface Vlan10
no ip address
no ip route-cache
--> no interface Vlan20
no ip address
no ip route-cache
interface Vlan30
no ip route-cache
ip http server
line con 0
exec-timeout 5 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
end
