Problem with POE WAP 581 and C9300-48UXM
cebit
Hello, I converted my network from a C350 -24 port to a C9300-48 UXM
With the C350 the WAP 581 run without any problems. On the C9300 I get the following Error Message: NOTE: The 5 GHz radio module was deactivated because the power source is no longer sufficient (802.3af).
I have four WAP 581 Access Points in use.
The WebUI Interface of the C9300 shows me a Consumption of 15.4 W per Port.
The following Values are displayed in the Overview:
Total Power Supports: 525W
Total Power Used: 61.6W
Total Power Available: 463.4W
I found the error, by chance I came across an old post here in the forum where the same error occurred.
The solution is that LLDP must be globally ebabled.
In case anyone runs into this issue. LLDP must be enabled globally on the switch and not just on the interface level. Without that you can't power both radios. Cisco didn't have any information about that in the documentation for this hardware.
7 Replies 7
balaji.bandi
C9300-48UXM - switch support PoE and PoE + i see you have enough power available.
The error you getting on Switch or WAP logs ?
what port the WAP connected on the switch   ? how is your configuration on the ports ?
what PSU was installed  on Cat 9300 ?
BB
The Error occurs on the WAP Access Ports, the Status LED on the WAP also lights up Blue, which results from the error.
The ports are:
33,34,35 and 36
The power supply is a PWR-C1-1100WAC
built-in.
I once tried to manually increase the PoE wattage on the ports in the C9300, unfortunately this didn't fix the error.
Port Configuration, all for Ports have the same Config
can you try different port start from 1-16 and what is the outcome ?
if the PSU 1150 - why it showing -Total Power Supports: 525W , how many PSU installed, what configuration ?
is this single switch or stack ?
from cisco switch cli post below command output :
show version
show power inline (complete)
show run interface x/x (where AP connected and having issue ?)
show interface x/x
BB
cebit
I tried different ports, all with the same result
It's a single switch.
With a 1100 W power supply, a PoE power of approx. 500W can be used on this switch. If more is required, another power supply must be installed, as stated in the technical documentation from Cisco
C9300>enable
Password:
C9300#show config
Using 9270 out of 2097152 bytes
! Last configuration change at 19:10:44 UTC Thu Dec 14 2023 by cisco
version 17.13
service config
service call-home
platform punt-keepalive disable-kernel-core
hostname C9300
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
boot system switch all flash:packages.conf
switch 1 provision c9300-48uxm
ip routing
no ip igmp snooping vlan X
login on-success log
crypto pki trustpoint SLA-TrustPoint
 enrollment pkcs12
 revocation-check crl
 hash sha256
crypto pki trustpoint TP-self-signed-994510399
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-994510399
 revocation-check none
 rsakeypair TP-self-signed-994510399
 hash sha256
crypto pki certificate chain SLA-TrustPoint
 certificate ca 01 nvram:CiscoLicensi#1CA.cer
crypto pki certificate chain TP-self-signed-994510399
 certificate self-signed 01 nvram:IOS-Self-Sig#2.cer
license boot level network-advantage
memory free low-watermark processor 131688
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
enable secret
enable password
username XXXXXX privilege 15 secret
redundancy
 mode sso
transceiver type all
 monitoring
class-map match-any system-cpp-police-ewlc-control
  description EWLC Control
class-map match-any system-cpp-police-topology-control
  description Topology control
class-map match-any system-cpp-police-sw-forward
  description Sw forwarding, L2 LVX data packets, LOGGING, Transit Traffic
class-map match-any system-cpp-default
  description EWLC Data, Inter FED Traffic
class-map match-any system-cpp-police-sys-data
  description Openflow, Exception, EGR Exception, NFL Sampled Data, RPF Failed
class-map match-any system-cpp-police-punt-webauth
  description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
  description L2 LVX control packets
class-map match-any system-cpp-police-forus
  description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
  description MCAST END STATION
class-map match-any system-cpp-police-high-rate-app
  description High Rate Applications
  description MCAST Data
class-map match-any system-cpp-police-l2-control
  description L2 control
class-map match-any system-cpp-police-dot1x-auth
  description DOT1X Auth
class-map match-any system-cpp-police-data
  description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
  description Stackwise Virtual OOB
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
  description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
  description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
  description DHCP snooping
class-map match-any system-cpp-police-ios-routing
  description L2 control, Topology control, Routing control, Low Latency
class-map match-any system-cpp-police-system-critical
  description System Critical and Gold Pkt
class-map match-any system-cpp-police-ios-feature
  description ICMPGEN,BROADCAST,ICMP,L2LVXCntrl,ProtoSnoop,PuntWebauth,MCASTData
,Transit,DOT1XAuth,Swfwd,LOGGING,L2LVXData,ForusTraffic,ForusARP,McastEndStn,Ope
nflow,Exception,EGRExcption,NflSampled,RpfFailed
policy-map system-cpp-policy
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 no ip address
 shutdown
 negotiation auto
interface TwoGigabitEthernet1/0/1
interface TwoGigabitEthernet1/0/2
interface TwoGigabitEthernet1/0/3
interface TwoGigabitEthernet1/0/4
interface TwoGigabitEthernet1/0/5
 switchport trunk native vlan Y
 switchport trunk allowed vlan Y,Z
 switchport mode trunk
interface TwoGigabitEthernet1/0/6
 switchport access vlan W
 switchport trunk native vlan W
 switchport trunk allowed vlan W
interface TwoGigabitEthernet1/0/7
interface TwoGigabitEthernet1/0/8
interface TwoGigabitEthernet1/0/9
 switchport access vlan X
 switchport trunk native vlan X
interface TwoGigabitEthernet1/0/10
 switchport access vlan Z
 switchport trunk native vlan Z
interface TwoGigabitEthernet1/0/11
interface TwoGigabitEthernet1/0/12
interface TwoGigabitEthernet1/0/13
interface TwoGigabitEthernet1/0/14
interface TwoGigabitEthernet1/0/15
interface TwoGigabitEthernet1/0/16
interface TwoGigabitEthernet1/0/17
interface TwoGigabitEthernet1/0/18
interface TwoGigabitEthernet1/0/19
interface TwoGigabitEthernet1/0/20
interface TwoGigabitEthernet1/0/21
interface TwoGigabitEthernet1/0/22
interface TwoGigabitEthernet1/0/23
interface TwoGigabitEthernet1/0/24
interface TwoGigabitEthernet1/0/25
interface TwoGigabitEthernet1/0/26
interface TwoGigabitEthernet1/0/27
interface TwoGigabitEthernet1/0/28
interface TwoGigabitEthernet1/0/29
interface TwoGigabitEthernet1/0/30
interface TwoGigabitEthernet1/0/31
 switchport trunk allowed vlan X,Y,W
interface TwoGigabitEthernet1/0/32
 spanning-tree portfast trunk
interface TwoGigabitEthernet1/0/33
 power inline static max 40000
interface TwoGigabitEthernet1/0/34
interface TwoGigabitEthernet1/0/35
interface TwoGigabitEthernet1/0/36
interface TenGigabitEthernet1/0/37
interface TenGigabitEthernet1/0/38
interface TenGigabitEthernet1/0/39
interface TenGigabitEthernet1/0/40
interface TenGigabitEthernet1/0/41
interface TenGigabitEthernet1/0/42
interface TenGigabitEthernet1/0/43
interface TenGigabitEthernet1/0/44
interface TenGigabitEthernet1/0/45
interface TenGigabitEthernet1/0/46
interface TenGigabitEthernet1/0/47
interface TenGigabitEthernet1/0/48
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface TenGigabitEthernet1/1/5
interface TenGigabitEthernet1/1/6
interface TenGigabitEthernet1/1/7
interface TenGigabitEthernet1/1/8
interface FortyGigabitEthernet1/1/1
interface FortyGigabitEthernet1/1/2
interface TwentyFiveGigE1/1/1
interface TwentyFiveGigE1/1/2
interface AppGigabitEthernet1/0/1
interface Vlan X
 description XXXXXXXXX
 ip dhcp client client-id ascii FJC27261CKK
 ip address XXX.XXX.XXX.XXX XXX.XXX.XXX.XXX
interface VlanY
 description YYYYYYYYYYY
interface Vlan Z
 description BBBBBBBBBBB
 no ip address
interface Vlan X
interface VlanY
 description XXXXXXXXXX
interface VlanW
 description WWWWWWWWWWWW
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http client source-interface VlanX
ip ssh bulk-mode 131072
control-plane
 service-policy input system-cpp-policy
line con 0
 stopbits 1
line vty 0 4
 password
 login
 length 0
 transport input ssh
line vty 5 31
 password
 login
 length 0
 transport input ssh
call-home
 ! If contact email address in call-home is configured as sch-smart-licensing@ci
sco.com
 ! the email address configured in Cisco Smart License Portal will be used as co
ntact email address to send SCH notifications.
 contact-email-addr sch-smart-licensing@cisco.com
 profile "CiscoTAC-1"
  active
  destination transport-method http
end
C9300#show power inline
Module   Available     Used     Remaining
          (Watts)     (Watts)    (Watts)
1           525.0       61.6       463.4
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Tw1/0/1   auto   off        0.0     n/a                 n/a   60.0
Tw1/0/2   auto   off        0.0     n/a                 n/a   60.0
Tw1/0/3   auto   off        0.0     n/a                 n/a   60.0
Tw1/0/4   auto   off        0.0     n/a                 n/a   60.0
Tw1/0/5   auto   off        0.0     n/a                 n/a   60.0
Tw1/0/6   auto   off        0.0     n/a                 n/a   60.0
Tw1/0/7   auto   off        0.0     n/a                 n/a   60.0
Tw1/0/8   auto   off        0.0     n/a                 n/a   60.0
Tw1/0/9   auto   off        0.0     n/a                 n/a   60.0
Tw1/0/10  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/11  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/12  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/13  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/14  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/15  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/16  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/17  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/18  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/19  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/20  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/21  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/22  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/23  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/24  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/25  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/26  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/27  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/28  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/29  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/30  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/31  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/32  auto   off        0.0     n/a                 n/a   60.0
Tw1/0/33  auto   on         15.4    Ieee PD             4     60.0
Tw1/0/34  auto   on         15.4    Ieee PD             4     60.0
Tw1/0/35  auto   on         15.4    Ieee PD             4     60.0
Tw1/0/36  auto   on         15.4    Ieee PD             4     60.0
Te1/0/37  auto   off        0.0     n/a                 n/a   60.0
Te1/0/38  auto   off        0.0     n/a                 n/a   60.0
Te1/0/39  auto   off        0.0     n/a                 n/a   60.0
Te1/0/40  auto   off        0.0     n/a                 n/a   60.0
Te1/0/41  auto   off        0.0     n/a                 n/a   60.0
Te1/0/42  auto   off        0.0     n/a                 n/a   60.0
Te1/0/43  auto   off        0.0     n/a                 n/a   60.0
Te1/0/44  auto   off        0.0     n/a                 n/a   60.0
Te1/0/45  auto   off        0.0     n/a                 n/a   60.0
Te1/0/46  auto   off        0.0     n/a                 n/a   60.0
Te1/0/47  auto   off        0.0     n/a                 n/a   60.0
Te1/0/48  auto   off        0.0     n/a                 n/a   60.0
Totals:          4    on    61.6
C9300#show run interface twoGigabitEthernet1/0/34
Building configuration...
Current configuration : 103 bytes
switchport trunk allowed vlan 1,3,22
end
C9300#show run interface twoGigabitEthernet1/0/1
Current configuration : 41 bytes
end
C9300#show run interface tenGigabitEthernet1/0/38
Current configuration : 42 bytes
end
Sure we have seen this issue on Cat 3850 - we enabled LLDP to fix the issue.
But cat 9300 we are ok, but good to know.
BB
