Problem with routing catalyst 3750
ComputerArt
Switch#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch(config)#interface Vlan2
Switch(config-if)#ip address 10.1.2.1 255.255.255.0
Switch(config-if)#no shutdown
Switch(config)#interface FastEthernet 0/1
Switch(config-if)#no switchport
Switch(config-if)#ip address 200.1.1.1 255.255.255.0
Switch(config)#ip route 0.0.0.0 0.0.0.0 200.1.1.2
The ip 20.1.1.2 is not pingabile.
How can I ping 20.1.1.2 and a possible DNS server with ip 20.1.1.10?
43 Replies 43
louis.tenga wrote:
Ok so without knowing the ipconfig on the PC's at 10.10.10.0/24 I can assume they are using 10.10.10.138 as their default gateway. Router 10.10.10.138 does not know how to get to 192.168.0.0/24 so whats happening is the ping from the 192.168.0.0 computers are going to the 10.10.10.0 pc's but they are responding to 10.10.10.138 since 192.168.0.0 is not on their network.
You might have to NAT the 192 network since you cannot access the Router to add routes.
Louis
That the confusing part though. If the default router doesn't have path back to the 192.168.0.0 computers then how do the 192.168.0.0 computers access the internet ?? Unless i am misunderstanding what the OP has said.
Jon
I can also ping the public 85.20.2.xx.
I can not pigare class 10.10.10.0
Without seeing the router config we can't really help.
As Louis said if you could  NAT the 192.168.x.x network that would be a solution but the 3750 doesn't support NAT so you can't do it.
Edit - it really depends on what you are trying to achieve. If you simply want to be able to contact the 10.10.10.x hosts then if you have access to them you could try changing the default-gateway to the 10.10.10.x address on the 3750.
Jon
akhbinda
Hello Claudio,
As of now from troubleshooting perspective since, we do not have access to the public router :
- Can you share results ping results from the 3750 switch to the router (10.10.10.138) using (1) source ip as 192.168.0.x network..(2) source ip as 10.10.10.x network..??
- may be use debug command(if possible) to see the packets or probably put a sniffer like wireshark on a machine and capture packets which will give packet details.For this you can configure local span on 3750 switch and span traffic bidirectionally to and fro for the port connecting to the unmanaged switch from this.
- how about pinging a 192.168.0.x machine from 10.10.10.x machine..can u ping..??
- please share traceroute results from 192.168.0.x machine to 10.10.10.138(router) and 10.10.10.x machine..
/Akhil
from 192.168.0.10
C:\Users\Utente>tracert www.google.it instradamento verso www.l.google.com [72.14.234.104]
su un massimo di 30 punti di passaggio:
Traccia
  1    <1 ms    <1 ms    <1 ms  192.168.0.1
  2     1 ms     1 ms     1 ms  10.10.10.138
  3     2 ms     2 ms     2 ms  10.0.0.254
  4    85 ms    84 ms    86 ms  78-7-239-29-static.albacom.net [78.7.239.29]
  5    82 ms    84 ms    84 ms  85-20-255-1-static.albacom.net [85.20.255.1]
  6    86 ms    83 ms    84 ms  217.220.187.145
  7    92 ms    93 ms   200 ms  mno-b1-link.telia.net [213.248.89.97]
  8   722 ms   125 ms   136 ms  ffm-bb1-link.telia.net [80.91.249.38]
  9   108 ms   108 ms   107 ms  ffm-b7-link.telia.net [80.91.249.105]
10   826 ms   102 ms   103 ms  google-ic-127675-ffm-b7.c.telia.net [213.248.89.
42]
11   102 ms   111 ms   102 ms  209.85.255.176
12   116 ms   116 ms   116 ms  209.85.251.112
13   111 ms   111 ms   111 ms  72.14.232.63
14   120 ms   111 ms   113 ms  mil01s07-in-f104.1e100.net [72.14.234.104]
Traccia completata.
C:\Users\Utente>tracert 10.0.0.254
Traccia instradamento verso 10.0.0.254 su un massimo di 30 punti di passaggio
  3     4 ms     3 ms     2 ms  10.0.0.254
Traccia completata.
C:\Users\Utente>tracert 10.10.10.1
Traccia instradamento verso 10.10.10.1 su un massimo di 30 punti di passaggio
  1     2 ms    <1 ms    <1 ms  192.168.0.1
  2     *        *        *     Richiesta scaduta.
  3     *        *        *     Richiesta scaduta.
  4     *     ^C
My ipconfig
Scheda Ethernet Connessione alla rete locale (LAN):
   Suffisso DNS specifico per connessione:
   Descrizione . . . . . . . . . . . . . : Atheros AR8132 PCI-E Fast Ethernet Co
ntroller
   Indirizzo fisico. . . . . . . . . . . : 20-CF-30-1F-CC-2B
   DHCP abilitato. . . . . . . . . . . . : No
   Configurazione automatica abilitata   : Sì
   Indirizzo IPv6 locale rispetto al collegamento . : fe80::d098:534e:77a6:8e7c%
12(Preferenziale)
   Indirizzo IPv4. . . . . . . . . . . . : 192.168.0.10(Preferenziale)
   Subnet mask . . . . . . . . . . . . . : 255.255.255.0
   Gateway predefinito . . . . . . . . . : 192.168.0.1
   IAID DHCPv6 . . . . . . . . . . . : 354471728
   DUID Client DHCPv6. . . . . . . . : 00-01-00-01-14-35-E8-D1-74-F0-6D-1F-8D-A4
   Server DNS . . . . . . . . . . . . .  : 212.216.112.112
   NetBIOS su TCP/IP . . . . . . . . . . : Attivato
Hello Claudio,
From the results it seems that the 10.10.10.1 machine doesn't know about 192.168.0.x network or else the default gateway set on the same is not correct.
Can you please confirm that as also suggested by Jon.
/Akhil
See my last message.
10.10.10.1 is not only not be reached.
But the router.
I also tried to insert:
ip route 10.10.10.0 255.255.255.0 FastEthernet1/0/24.
Not working!
That's ok. I want you to share output of the command ----->
ping ip 10.10.10.138 source  192.168.0.1
so do this on the switch ------>  switch# ping ip 10.10.10.138 source  192.168.0.1
/Akhil
Switch#ping ip 10.10.10.138 source  192.168.0.1
Sending 5, 100-byte ICMP Echos to 10.10.10.138, timeout is 2 seconds:
Packet sent with a source address of 192.168.0.1
Success rate is 0 percent (0/5)
Switch#ping ip www.google.it source  192.168.0.1
Translating "www.google.it"...domain server (255.255.255.255) [OK]
Sending 5, 100-byte ICMP Echos to 209.85.135.104, timeout is 2 seconds:
That sounds to me like when you ping 10.10.10.138 that it cannot reply because it doesn't have a route back to the 192 network.
Where I insert the reverse route?
Switch#ping ip 10.10.10.100 source 192.168.0.1
Sending 5, 100-byte ICMP Echos to 10.10.10.100, timeout is 2 seconds:
MY ip 10.10.10.100
C:\Windows\system32>route print
Elenco interfacce
16...1a 4b d6 8d 54 e9 ......Microsoft Virtual WiFi Miniport Adapter
12...48 5b 39 3f 89 0c ......Atheros AR8131 PCI-E Gigabit Ethernet Control
11...1c 4b d6 8d 54 e9 ......Atheros AR9285 Wireless Network Adapter
  1...........................Software Loopback Interface 1
18...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
21...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #3
19...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #4
IPv4 Tabella route
Route attive:
     Indirizzo rete             Mask          Gateway     Interfaccia Metri
          0.0.0.0          0.0.0.0     10.10.10.138     10.10.10.100     20
       10.10.10.0    255.255.255.0         On-link      10.10.10.100    276
     10.10.10.100  255.255.255.255         On-link      10.10.10.100    276
     10.10.10.255  255.255.255.255         On-link      10.10.10.100    276
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
      169.254.0.0      255.255.0.0         On-link      10.10.10.100     30
  169.254.255.255  255.255.255.255         On-link      10.10.10.100    276
      192.168.0.0    255.255.255.0      10.10.10.80     10.10.10.100     21
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    306
        224.0.0.0        240.0.0.0         On-link      10.10.10.100    276
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    306
  255.255.255.255  255.255.255.255         On-link      10.10.10.100    276
Route permanenti:
   Indirizzo rete             Mask   Indir. gateway Metrica
          0.0.0.0          0.0.0.0      192.168.0.1  Predefinito
IPv6 Tabella route
Route attive:
Interf Metrica Rete Destinazione      Gateway
18     58 ::/0                     On-link
  1    306 ::1/128                  On-link
18     58 2001::/32                On-link
18    306 2001:0:5ef5:79fd:10c4:3a06:f5f5:f59b/128
                                    On-link
12    276 fe80::/64                On-link
18    306 fe80::/64                On-link
18    306 fe80::10c4:3a06:f5f5:f59b/128
                                    On-link
12    276 fe80::fd44:3574:2280:ae24/128
                                    On-link
  1    306 ff00::/8                 On-link
18    306 ff00::/8                 On-link
12    276 ff00::/8                 On-link
Route permanenti:
  Nessuna
If it didn't have a route back then there would be no internet access.
Jon
Switch#ping ip 10.10.10.1 source  192.168.0.1
Sending 5, 100-byte ICMP Echos to 10.10.10.1, timeout is 2 seconds:
Sending 5, 100-byte ICMP Echos to 209.85.135.106, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 109/117/126 ms
Switch#
Forgot about it being able to get to the internet and back though...
