Problem with routing catalyst 3750
ComputerArt
Switch#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch(config)#interface Vlan2
Switch(config-if)#ip address 10.1.2.1 255.255.255.0
Switch(config-if)#no shutdown
Switch(config)#interface FastEthernet 0/1
Switch(config-if)#no switchport
Switch(config-if)#ip address 200.1.1.1 255.255.255.0
Switch(config)#ip route 0.0.0.0 0.0.0.0 200.1.1.2
The ip 20.1.1.2 is not pingabile.
How can I ping 20.1.1.2 and a possible DNS server with ip 20.1.1.10?
Hello Claudio,
From the results it seems that the 10.10.10.1 machine doesn't know about 192.168.0.x network or else the default gateway set on the same is not correct.
Can you please confirm that as also suggested by Jon.
/Akhil
43 Replies 43
louis.tenga
That IP address is not part of any of the above networks?  That would be handled by your default route.
I tried pinging that address and I get no response.
Did you mean that 200.1.1.2 is not pingable?
Leo Laohoo
Is "ip routing" enabled?
Jon Marshall
In addition to Leo's suggestion does the default router in your diagrma have routes back to the vlans on your 3750 switch. If not you either need to run a routing protocol between the 3750 and the default router or add static routes to the default router eg.
ip route 10.1.2.0 255.255.255.0 200.1.1.1
etc. for each vlan
in addition how is your default router exchanhing routes with the corporate network ??
Jon
  Jon beat me to it  but he is correct unless you have  statics pointing back to your 3550 the net router has no idea what to do with those packets because you are not running a dynamic routing protocol.
I can ping the 20.1.1.1 can not ping the rest of the network 20.1.1.x.
I can also surf the internet.
I need access to DNS servers on the network 20.1.1.x.
ComputerArt
Sorry I made a mistake, that's the right image
Switch(config-if)#ip address 20.1.1.1 255.255.255.0
I need to see the network 20.1.1.x
Do a show ip route on the 3550 and the default router.
Make sure that the default router has routes to the 10.1.2.0, 10.1.3.0 and 10.1.10.0 networks.
Try pinging from the default router to hosts on those networks?
Are there any ACL's that could be blocking?
Sorry, I did a bit of confusion.
Here is the scheme of my network with the configuration of 3750.
Building configuration...
Current configuration : 1419 bytes
version 12.2
service config
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
switch 1 provision ws-c3750-24ts
system mtu routing 1500
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1/0/1
interface FastEthernet1/0/24
no switchport
ip address 10.10.10.80 255.255.255.0
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.138
ip http server
control-plane
line con 0
line vty 5 15
end
Switch#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.10.10.138 to network 0.0.0.0
     10.0.0.0/24 is subnetted, 1 subnets
C       10.10.10.0 is directly connected, FastEthernet1/0/24
C    192.168.0.0/24 is directly connected, Vlan1
S*   0.0.0.0/0 [1/0] via 10.10.10.138
I did not create or modify ACL
So I can ping the 192.168.0.1, 10.10.10.80 and I can go on the Internet.
I can not ping the 10.10.10.138, 10.10.10.1, and the network 10.10.10.x
Thanks for your help and sorry for the confusion
Ping it from where ie. a client in the 192.168.1.x network/the switch or the router ???
The unmanaged switch - what device is it ie. make and model ??
Jon
Ping from the switch 3750 all 10.10.10.xe 192.168.0.x
From pc "192.168.0.10" ping to 192.168.0.11 192.168.0.1, 10.10.10.80 and www.google.it.
From Pc  "192.168.0.10" not ping the 10.10.10.1 and 10.10.10.2 and 10.10.10.138 network 10.10.10.x
The routing is not the case with the network 10.10.10.x except for 10.10.10.80.
The switch is a simple Linksys 16-port.
Claudio,
It sounds to me like the router at 10.10.10.138 does not have a route back to 192.168.0.0/24.
Can you verify with a 'show ip route' on 10.10.10.138 ?
It does not appear you are running any routing protocols or have a static route setup.
10.10.10.138 is the router Pirelli Telecom-Italy can not access.
Ok so without knowing the ipconfig on the PC's at 10.10.10.0/24 I can assume they are using 10.10.10.138 as their default gateway. Router 10.10.10.138 does not know how to get to 192.168.0.0/24 so whats happening is the ping from the 192.168.0.0 computers are going to the 10.10.10.0 pc's but they are responding to 10.10.10.138 since 192.168.0.0 is not on their network.
You might have to NAT the 192 network since you cannot access the Router to add routes.
Because if I replace a 3750 router to work?
How do the NAT 192?
