problem with the show runn
serenity001
hi .. i have a 3560 switch and all port are configured as access mode except the gig port is configured as trunk
now when i do show runn i see new commands on the fastethernet ports
like
switch port mode trunk
my ios image is
c3560-ipbasek9-mz.122-46.SE.bin
any 1 have a solution for this ??
regards
shevchiksv
Do you define explicitly switcport mode access?
lffrwatson
put the ports in Access mode and access vlans.
switchport mode access
switchport access vlan xxx
Does your gig port lead to a router or another switch? Don't randomly put your ports in access mode if you don't know what they're connecting to.
--John
HTH, John *** Please rate all useful posts ***
thx ppl
i have attached two files ,
first i have erased all the config then do multiple show runn please see how new thing is coming under random ports (the file is befor config)
thin i configuerd the switch with some vlans and connect it to another switch on port f0/24
i can ping and telnet, i meant the switch is working .. but didn't get why this commands are coming
