Problems with a Switch Catalyst 3560
Kinai2008
Community Member
Hi.
We have a Switch Catalyst 3560 as the hub of our net One of its ports is connected to a Gateway, that we don't administer.
When we connect a new computer to the switch, there is times that you can connect to this equipment from outside until that you make a ping since the new equipment to any address out of the net.
Any can help me?
Thanks.
Kinai.
benson.low
Check the machine IP's, netmask and gateway and make sure it is inline with the gateways.
Check the switch counters and see any errors that culd arise.
Beno
