Problems with Cisco 2960X
Twilo
Hi all,
I need your help regarding some issue with 2960X.
I'm running MD version  c2960x-universalk9-mz.152-2.E6.bin, but for some reason some PCs lost Ip address random, and Ip phones (Alcatel) for some reason reboots, but not always.
Have you seen this problem before??
We have 3  WS-C2960X-48FPD-L in stack, before with 2960S all worked ok.
11 Replies 11
Julio E. Moisa
Any logs are generated during these events?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
thanks for your reply, no logs.
I have log from Alcatel Phone;
20/07/17 02:48:49 000002M|19/03/0/052|=3:0378=IP Phone sig incident 6,(19,1),00:80:9f:76:be:71,3437
20/07/17 02:51:09 000002M|00/00/0/000|=4:0426=IPTOUCH terminal reset 13,(0,0),00:80:9f:76:be:71,3437
20/07/17 05:48:47 000002M|19/03/0/052|=3:0378=IP Phone sig incident 6,(19,1),00:80:9f:76:be:71,3437
20/07/17 05:51:07 000002M|00/00/0/000|=4:0426=IPTOUCH terminal reset 13,(0,0),00:80:9f:76:be:71,3437
20/07/17 11:47:18 000002M|19/03/0/052|=3:0378=IP Phone sig incident 6,(19,1),00:80:9f:76:be:71,3437
20/07/17 11:49:39 000002M|00/00/0/000|=4:0426=IPTOUCH terminal reset 13,(0,0),00:80:9f:76:be:71,3437
20/07/17 12:09:51 000002M|19/03/0/052|=3:0378=IP Phone sig incident 6,(19,1),00:80:9f:76:be:71,3437
20/07/17 12:12:11 000002M|00/00/0/000|=4:0426=IPTOUCH terminal reset 13,(0,0),00:80:9f:76:be:71,3437
Terminal reset due a UDP packet lost (error 13).
It could be QoS??
Hi Mauro,
It doesn't look like QoS problem, also I see you have the latest IOS released. Have you identified if the problem is on the 3 switches or just on one?
Thanks Julio
the issue is with 3 devices, before with 2960s all worked ok.
regards.
Thank you Mauro,
Is possible to provide the config?
Sorry,
it's not possible but the config is the same as the previous 2960S
regards
Thank you Mauro, it is ok.
The Cisco 2960X is a very good switch, so it think it could be a bug, if you have contract with Cisco I recommend open a case with the Cisco TAC.
Prior, could you please verify the outputs of the following commands:
show switch
show switch stack-ports
Hi Julio
#show switch stack-ports
  Switch #    Port 1       Port 2
    1           Ok           Ok
    2           Ok           Ok
    3           Ok           Ok
#show switch
Switch/Stack Mac Address : 6899.cdfc.b900
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 6899.cdfc.b900       15     4       Ready
 2       Member 00e1.6d5b.3100     13     4       Ready
 3       Member 00e1.6d66.2c00     11     4       Ready
yes I have case with Cisco TAC.
regards
Hi Mauro,
Great, yes, your stack looks fine.
Please keep us posted about the findings by the Cisco TAC.
Hello
Curious, What discovery protocol are you using  CDP/LLDP?
Show LLDP errors
Show CDP traffic.
access-list 100 permit udp any any
debug condition interface X/X
debug ip packet detail 100
res
Paul
Kind Regards
Paul
Hi Mauro Ciccone,
Where is DHCP server configured?
Can you please attach the show tech of your switch?
Spooster IT Services Team
