Process level in Catalyst 4503E
maucapina
Hi Guys
I have a Catalyst 4503E switch with a Supervisor II+TS. I have monitoring for several weeks and I see that the process is over 40%:
SwCore_1#sh processes cpu history
    1111111111111111111222221111111111111111111111111222221111
    2222444442222222222888883333311111333335555511111000002222
100
90
80
70
60
50
40
30                    *****
20                    *****               *****     *****
10 **********************************************************
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
    2222223232322232323222212132212222223232222232323122323232
    8480902201048000100084788820899390813201878801504987200157
100
90
80
70
60
50
40                                               *         *
30 * * * * * * * * * * * * * * * * * * * * ***** * * *** * **
20 ******#***##****#*********#*********#***##**#*#*#**#****#*
10 ##########################################################
             0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
    4333344444444444444444444444444444444444444444444444444444444444444444
    0878812210221334335335333535534355435455454354354333353333435353333354
100
90
80
70
60
50                   *  *   * **   **  * ** *  *  *     *      * *     *
40 **********************************************************************
30 **********************************************************************
20 **********************************************************************
10 ######################################################################
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
I have doubts about the behavior. I sent the show process cpu sorted too:
SwCore_1#show processes cpu sorted
CPU utilization for five seconds: 11%/0%; one minute: 14%; five minutes: 14%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  41   572362468 481661154       1188  5.91%  7.72%  8.09%   0 Cat4k Mgmt LoPri
  40   192315428 624250320        308  4.07%  4.30%  4.21%   0 Cat4k Mgmt HiPri
  80     9612020  98428005         97  0.47%  0.53%  0.53%   0 Spanning Tree
  77    21263268  60073083        353  0.31%  0.50%  0.45%   0 IP Input
128     3666112  54408528         67  0.23%  0.20%  0.21%   0 HSRP (Standby)
  13    13250492  32542870        407  0.15%  0.13%  0.15%   0 ARP Input
141          48     66829          0  0.07%  0.07%  0.07%   0 RADIUS
  34      743720  12028085         61  0.07%  0.09%  0.09%   0 IDB Work
   9           0         2          0  0.00%  0.00%  0.00%   0 Timers
  10           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  11           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  12           0         1          0  0.00%  0.00%  0.00%   0 ifIndex Receive
   7    20338512   2047578       9932  0.00%  0.21%  0.18%   0 Check heaps
Mohamed Sobair
Level 7
Level 7
There is no unusual behaviour from the (show processes cpu sorted) command. Could you please run this command again when the CPU reaches 40 or above 40% and post the output here.
As ageneral note, 40% is not Scary Percentage of CPU utilization, but for checking purposes , you should figure what most consumes your CPU.
Mohamed
   As previous poster said that is not high . these switches will show 30% with nothing running on them .  If you worried about it then go thru the high cpu doc.
http://www.cisco.com/en/US/partner/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml
Thanks Glen
Thanks Mohamed
