Promiscuous port mapping to different Isolated PVLANs within a single Primary PVLAN?
I am working on a unique system & switch configuration where there are middle-man workstations that communicate with each other and a community of servers. Each workstation must also be able to communicate with one single isolated workstation/PC. This is all being configured on one Catalyst 3650 switch. Below is a diagram depicting the goal of the project.
I have been able to create the proper communication between VLAN 201 (i.e servers), WS-1, and VLAN 202 (isolated PC 1) with this config guide https://learningnetwork.cisco.com/docs/DOC-16110. With  my current configuration, WS-1 can ping VLAN 202 and VLAN 201 but VLAN 201 and VLAN 202 cannot ping each other.
When I attempt to expand the configuration by adding a second workstation and isolated VLAN to the primary VLAN  I am getting errors stating that only 1 isolated VLAN can be associated with the primary VLAN.
Switch(config)#int Gi1/0/11
Switch(config-if)#switchport mode private-vlan promiscuous
Switch(config-if)#switchport private-vlan mapping 2 203
%Command rejected: invalid private vlan association between vlan2 and vlan203. Isolated VLAN 202 is already associated with VLAN 2.
Switch(config-if)#exit
Is it possible to configure promiscuous ports with there own isolated PVLAN as a workaround to avoid having multiple isolated PVLANS on the Primary PVLAN?
Is this config even viable for what I am looking to accomplish?
Thanks!
Current Config Info
Primary Secondary Type              Ports
2       201       community         Gi1/0/1, Gi1/0/10, Gi1/0/11
2       202       isolated          Gi1/0/10, Gi1/0/20
none    203       isolated
vlan 2
 name prim-vlan
  private-vlan primary
  private-vlan association 201-202
end
vlan 201
 name server-comm
  private-vlan community
end
vlan 202
 name iso-1
  private-vlan isolated
end
vlan 203
 name iso-2
end
interface GigabitEthernet1/0/1
 switchport private-vlan host-association 2 201
 switchport mode private-vlan host
end
interface GigabitEthernet1/0/10
 switchport private-vlan mapping 2 201-202
end
Current configuration : 120 bytes
interface GigabitEthernet1/0/11
end
interface GigabitEthernet1/0/20
 switchport private-vlan host-association 2 202
end
interface GigabitEthernet1/0/21
end
kubn2
I don't think you can do it with this MITM computers on the path. I suggest to make inter-vlan routing and with ACLs limit which hosts/vlans can comunicate with others
