Provide level 7 access to https management
Jason Fraioli
Level 3
Level 3
I currently have the following config for level 7 access. I just want the level 7 folks to be able to enable/disable ports and to add descriptions to interfaces. It works fine if I SSH to the switch, however, it wants level 15 access for the HTTPS management. Any idea how to enable HTTPS access for the level 7 folks?
privilege exec level 7 show
privilege exec level 7 configure terminal
privilege configure level 7 interface
privilege interface level 7 shutdown
privilege interface level 7 description
Edison Ortiz
Hi Jason,
I'm afraid is not possible. In order to access the http files in the router, the user must have a high level authentication.
One way to make simple management for novice users while keeping some kind of privilege security, is by implementing menus in the router.
http://www.cisco.com/en/US/docs/ios/12_4/cfg_fund/configuration/guide/cfh400_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1001601
HTH,
__
Edison.
looks like a viable option, although I can't figure out how to associate the menu to a login privilege. Do you have any advice on how to accomplish that? The documentation really doesn't discuss that at all.
The menu will be used instead of the login privilege.
The users will be only be able to perform tasks within the menu.
HTH,
__
Edison.
