PVST Calculation
vishalpatil86
Level 7
Level 7
Dear All,
How PVST works?
can anyone explain woth the help of an example?
Vishal
acually, each switch believes to be an STP root until it receives a BPDU with better priority than its own one within the VLAN.
Is it clear now?
HTH,
Milan
17 Replies 17
cadet alain
PVST is just STP  but with an STP instance for each VLAN and by default all VLANs wiil follow the same STP topology but you can configure your switches so that there is a different STP topology per VLAN.
If you need more info on STP then we'll be glad to help.
Regards.
Alain
Dear Alain,
Thanks for the reply!!!  Now suppose there are 10 switches running vlan 1, 10 and 20...
Now, for each vlan there is separate instance of STP on all switches or
each vlan has separate instace of STP on individual switches?
a separate instance per VLAN on each switch.
Regards.
Alain
Ok Alain, now we mover somewhat further. I have topology which is attahced here.
Just want to know how vlan 99 chosses the 223 switch over 450e core switch even if mac id of 4506e is lower than that of 223 switch?
check the STP for VLAN 99 by sh spanning-tree vlan 99 commands on both switches.
You might see either of them having not the default STP priority configured for that VLAN.
Possibly your 223 swict had been configured as the STP root  for VLAN 99 in the past?
HTH,
Milan
hi milan,
all the values are at their deafault only
Can you post the output of the 'sh spanning-tree vlan 99' please.
Adam
Dear Adam,
Below is the output for show spanning tree for vlan 99 of all the switches
220
Root ID    Priority 32867
Address 0024.f98c.xxxx
Bridge ID  Priority 32867  (priority 32768
Address 0024.f9ce.xxxx
219
VLAN0099
238
VLAN0099
Address 0025.4610.xxxx
237
Address 34bd.c8b6.xxxx
236
Address 203a.07fb.xxxx
235
Address 34bd.c8f6.xxxx
234
VLAN0099
227
228
229
230
231
232
Cost 32
233
253
Address 001d.7040.xxxx
221
Address 0024.f91c.xxxx
222
223
Address 0024.f9c4.xxxx
223
225
226
240
Address e8ba.7084.xxxx
241
244
245
spanning tree instance d oes not exist
246
247
248
Cost 4
Address 0024.f9cd.xxxx
239
Address 18ef.6350.xxxx
249
Address 0024.f761.xxxx
250
242
251
252
243
which of the switches is your 4506?
Switch 253?
What does show spanning tree 99 show on it?
Istn't ther epossible youe VLAN 99 is discontinous somewhere?
In that case you would see two STP roots - each for one part of the discontinous VLAN 99!
HTH,
Milan
yes Milan, 4506e is 253. and there is discontinuity. But my doubt is root bridge is elected among all the switches.. am I right?
Please educate me!!!!
No,
the root is elected per VLAN among the switches which can "see" each others.
So for a discontinous VLAN you've got two roots finally - one per each continuous part of the VLAN.
HTH,
Milan
Dear Milan,
Instead of saying can see each other, can we say which are connected in loop or in chain?
no we should say which see each other's BPDUs for the coresponding vlan instance.
Regards.
Alain
Dear Alain,
please find attahced sheet. in this, there are two side of switch. one is looped connected to one gig port of core and other is chained connected to other gig port of core.  Now, you meant to say that these two sides of switched don't see each others BPDU??
