PVST+ Rapid Spanning Tree Convergence Issue
jfraasch
Level 3
Level 3
I am having a hard time getting my PVST+ Rapid Spanning Tree to converge in less than 15 or 20 seconds.
I am using a Cisco IE-5000 as the root bridge and there are loops and subloops involved so I am not saying this is a simple mesh.
The way it goes is:
IE5000A<------------------->IE5000B<----------------------->IE5000C
  IE4000A<->IE4000B<->IE4000C        IE4000D<->IE4000E<->IE4000F       IE4000G<->IE4000H---end
So you can see the loops.
I just configured normal PVST+ Rapid spanning tree.  The ports between all the switches are trunked.
The root is the IE5000A.  I unplug between IE5000A and IE5000B and I lose packets between a laptop plugged into 5000A and 5000C for 20 seconds. And then I plug the fiber back in and I drop packets again for 20 seconds.
Is there a standard config I should look at or am I missing something.  Do I have to play with timers> I thought Rapid would have 2 seconds failover.
James
Hi James,
In addition to the suggestions of other friends here, RSTP absolutely requires you to properly configure edge ports using spanning-tree portfast [ trunk ] command. This is because one of the RSTP mechanisms for fast convergence, the Proposal/Agreement, leads to temporary blocking of links to prevent loops, and the unblocking of the links is based on receiving an Agreement BPDU from the downstream switch. However, non-switching devices, such as PCs, laptops, servers, routers, firewalls etc. do not speak RSTP and cannot send back an Agreement - and so, when the temporary blocking hits a port to such a device, this port needs to go through Discarding -> Learning -> Forwarding sequence that takes 30 seconds by default.
I cannot emphasize this enough: In RSTP, all ports that are connected to "end hosts" (or better said, Layer2-terminating device) must be configured with spanning-tree portfast [ trunk ] command (use trunk if the port is a trunk, such as for ports toward servers with VMs, firewalls, or routers on stick). Otherwise, during topology changes, these ports will be blocked and cause outage for 2x forward_delay seconds.
Best regards,
Peter
7 Replies 7
johnd2310
Level 8
Level 8
Have you checked that all the switches are running rapid-pvst?  What is the output of "show spanning-tree vlan x" for each switch where vlan x is the vlan the PC is connected to?
John
**Please rate posts you find helpful**
Sure thing. Configs of IE5000A and IE4000A are below. All the switches are configured the same. But, good point about double checking that Rapid is enable on all switches. There are a total of 40...so that design keeps going just a little longer with the backbone loop and subloop.
version 15.2
no service pad
service password-encryption
hostname MSHFSW02001
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$Z8du$1RW/jsjgQG6Pm5gDMRNjj1
username cisco password 7 030752180500
aaa new-model
aaa group server radius MSH
server name MSHSVRNSS01
server name MSHSVRNSS02
ip radius source-interface Vlan290
aaa authentication login userAuthentication group MSH local
aaa authentication dot1x default group MSH
aaa authorization exec userAuthorization group MSH local if-authenticated
aaa authorization exec MSH group MSH
aaa authorization network default group MSH
aaa accounting dot1x default start-stop group MSH
aaa accounting exec default start-stop group MSH
aaa accounting system default start-stop group MSH
aaa session-id common
system mtu routing 1500
ip domain-name ASTS-MSH.com
vtp mode transparent
ptp mode e2etransparent
crypto pki trustpoint TP-self-signed-3411298176
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3411298176
revocation-check none
rsakeypair TP-self-signed-3411298176
crypto pki certificate chain TP-self-signed-3411298176
license boot level ipservices
dot1x system-auth-control
spanning-tree mode rapid-pvst
alarm profile defaultPort
alarm not-operating
syslog not-operating
notifies not-operating
alarm profile MLK
alarm link-fault
relay-major link-fault
alarm contact 2 description MLK
alarm contact 2 severity major
alarm relay-mode negative
no alarm facility temperature primary notifies
vlan internal allocation policy ascending
vlan 201,250,260,270,290,301
lldp run
interface GigabitEthernet1/1
description Terminal Server
switchport access vlan 201
switchport mode access
alarm profile MLK
interface GigabitEthernet1/2
description MANAGEMENT
switchport access vlan 270
authentication host-mode multi-domain
authentication order mab dot1x
authentication priority dot1x mab
authentication port-control auto
mab
dot1x pae authenticator
interface GigabitEthernet1/3
description MLK VMISA
alarm profile MLK
interface GigabitEthernet1/4
shutdown
interface GigabitEthernet1/5
description AXLE COUNTER
switchport access vlan 301
interface GigabitEthernet1/6
shutdown
interface GigabitEthernet1/7
description MLK VMISB
alarm profile MLK
interface GigabitEthernet1/8
description Management VLAN TEST
interface GigabitEthernet1/9
description RADIO
switchport trunk native vlan 260
switchport trunk allowed vlan 260
switchport mode trunk
interface GigabitEthernet1/10
description ZONE CONTROLLER
switchport access vlan 250
interface GigabitEthernet1/11
interface GigabitEthernet1/12
shutdown
interface GigabitEthernet1/13
shutdown
interface GigabitEthernet1/14
shutdown
interface GigabitEthernet1/15
shutdown
interface GigabitEthernet1/16
shutdown
interface GigabitEthernet1/17
shutdown
interface GigabitEthernet1/18
shutdown
interface GigabitEthernet1/19
shutdown
interface GigabitEthernet1/20
shutdown
interface GigabitEthernet1/21
shutdown
interface GigabitEthernet1/22
shutdown
interface GigabitEthernet1/23
shutdown
interface GigabitEthernet1/24
shutdown
interface GigabitEthernet1/25
description To Test Track
interface GigabitEthernet1/26
description To OCC
interface GigabitEthernet1/27
description To Bywood Trunk
interface GigabitEthernet1/28
description to Fairfield Subloop
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan270
ip address 10.20.14.21 255.255.255.0
ip forward-protocol nd
ip http server
ip http secure-server
snmp-server group admin v3 auth
snmp-server community MSHL RW
snmp-server enable traps syslog
snmp-server enable traps vlan-membership
snmp-server host 10.20.22.23 version 3 auth admin
radius server MSHSVRNSS01
line con 0
line vty 0 4
password 7 104D000A0618
login authentication userAuthentication
transport input ssh
line vty 5 15
ntp server 10.20.22.130
end
_____________________________________-
And the IE4000 is
version 15.2
no service pad
hostname MSHFSW03001
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$lbiU$K6LyUq1LtCvmLy8O0WYsE.
username cisco password 7 104D000A0618
aaa new-model
ip radius source-interface Vlan270
aaa authorization network default group msh
crypto pki trustpoint TP-self-signed-272986752
subject-name cn=IOS-Self-Signed-Certificate-272986752
rsakeypair TP-self-signed-272986752
crypto pki certificate chain TP-self-signed-272986752
alarm not-operating
alarm profile MLK
alarm link-fault
vlan 201,260,270,301
lldp run
description To Subloop West Yard G1/26
description To Subloop Walnut G1/1
interface FastEthernet1/5
alarm profile MLK
spanning-tree portfast edge
interface FastEthernet1/6
description Radio
interface FastEthernet1/7
shutdown
interface FastEthernet1/8
interface FastEthernet1/9
description Axle Counter
alarm profile MLK
interface FastEthernet1/10
shutdown
interface FastEthernet1/11
shutdown
interface FastEthernet1/12
mab
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan270
ip address 10.20.14.22 255.255.255.0
no ip route-cache
ip default-gateway 10.20.14.254
ip http server
snmp-server group MSH v3 auth
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps transceiver all
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps license
snmp-server enable traps bfd
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps ether-oam
snmp-server enable traps cluster
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps energywise
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps event-manager
snmp-server enable traps power-ethernet police
snmp-server enable traps cpu threshold
snmp-server enable traps rep
snmp-server enable traps vstack
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps stackwise
snmp-server enable traps ethernet cfm alarm
snmp-server enable traps alarms informational
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps errdisable
snmp-server enable traps mac-notification change move threshold
address ipv4 10.20.22.21 auth-port 1645 acct-port 1646
key 7 0812495E1D18544E445B4D
radius server MSHSVRNSS02
address ipv4 10.20.22.150 auth-port 1812 acct-port 1813
key 7 0235014B1F075E781A1E48
banner login CCCWARNING - PRIVATE ELECTRONIC DEVICE - ACCESS PROHIBITED
This is a private network device. Access to this device is
not authorized. Any attempt for unauthorized access will be logged
and appropriate legal action will be taken.
line con 0
line vty 0 4
password 7 01100F175804
transport input ssh
line vty 5 15
ntp server 10.20.22.15
end
I'll get the output of the command tomorrow when I get back to those babies.
Hi James,
Best regards,
Peter
Thanks Peter. In this case. I haven't deployed the system yet so literally the only things connected are the fiber ports between all switches and the two laptops in question. Which, I just noticed is in port 8 of IE5000A. I will change that to portfast.
Peter, that did the trick. I had to enable two new ports since I don't have the Authentication Server up and running. So when I enabled and configured ports G1/8 on the two IE5000s, I only put them in access mode but did not put Portfast on. I just ran the test again and BOOM, no dropped packets. Holy crap my heart was in my stomach all night.
Thanks for the suggestion and quick review! Much appreciated!
James
Francesco Molino
as @johnd2310 said, please check all your switches are configured with rpvst and also share your config/ spanning-tree vlan output.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
