08-06-2012 08:06 PM - edited 03-07-2019 08:11 AM
Hi all,
I have a C6513 system that is in hybrid mode (SE = CatOS 8.2(2) and RP = IOS 12.1(22)E1) and I'd like to upgrade it to native IOS (finally :). I've looked at Cisco DocID 12031, which specifies on pg19 that it a good idea (although not required) to have a boot image of the IOS in the MSFC's bootflash. I do currently have the 12.1(22)E1 boot image there. My question is, when I upgrade to native IOS, do I still need the boot image after the conversion? It also looks like (via FN) up to the end of the 12.1 train that there were boot images available, and that in 12.2 train there were not... Is that true? I may be stuck on 12.1 anyways, looks like the 12.2 train increased the DRAM requirement to 256M (I only have 128M on the Sup2A's I have.)
And, does anyone know when the naming convention went from "c6sup22-" to "c6k222-"? The naming conventions sure are confusing...
Thanks!
Will
Solved! Go to Solution.
08-09-2012 10:42 PM
"My question is, when I upgrade to native IOS, do I still need the boot image after the conversion?"
No, that boot image is just a failsafe incase something bad goes wrong during the upgrade process. In that case at the very least you could boot that image and be able to access flash, etc and try to resolve the issue.
08-09-2012 08:39 PM
Anyone?
08-09-2012 10:42 PM
08-10-2012 06:52 AM
Does anyone know if the boot image IOS ver has to match the new native IOS ver? (I.e. can I just use the current boot img I now have on the MSFC?)
08-10-2012 10:20 AM
Doesn't have to match though they will always "recommend" that it does.
