Q-MATIC TP3115 Printer
Hello mates,
We have Queuing printer model Q-MATIC TP3115 in one of our branches connected to Cisco 3560 Switch and its flapping so I did some changes on the switch port.
Below is the switch port configuration before change and after but still the printer is flapping , can anyone help with this matter if you work with the same issue before.
Switch port configuration before the change:
interface GigabitEthernet0/15
switchport access vlan 153
switchport mode access
switchport voice vlan 154
switchport port-security maximum 3
switchport port-security violation protect
switchport port-security aging type inactivity
storm-control broadcast level 1.00
spanning-tree portfast
no spanning-tree bpduguard enable
end
Switch port configuration after the change:
description **** QMATIC PRINTER ****
speed 10
duplex full
Here is show version of the switch :
Cisco IOS Software, C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 21-Aug-08 15:26 by nachen
Image text-base: 0x00003000, data-base: 0x01A00000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWARE (fc1)
Switch uptime is 21 hours, 24 minutes
System image file is "flash:c3560-advipservicesk9-mz.122-46.SE.bin"
cisco WS-C3560G-24PS (PowerPC405) processor (revision H0) with 122880K/8184K bytes of memory.
Last reset from power-on
9 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3560G-24PS     12.2(46)SE            C3560-ADVIPSERVICESK9-M
Configuration register is 0xF
more over i check the printer online DOCs but there is nothing mentiond about what will be the SW port configuration.
http://www.datalex.gr/files/pdf/QMatic%20TP3115.pdf?phpMyAdmin=a44be1c193e15259a1643c233cb29f26
also when i connect it to a normal HUB its working fine.
Please Help
IAN WHITMORE
Level 4
Level 4
Have you tried all port speed/duplex combinations? What was the bub? 10 half?
Ian
Actuallu i trird it also and its not working .
Hi  ,
I hope that you are well . Have you found the root cause to this . I have a very similar issue .
Take care and I appreciate any assistance .
actually vendor came and did some changes from thier end but from our side we kept our configuration as its
