QinQ in single switch
active.hub2
I am trying to learn dot1q tunneling in GNS3 with IoS.  I created a scenario to connect PCs in VLAN2 separated apart with the following switches.  The master switch has to be configured to pass vlans 2,3 through vlan100. I am not able to ping PC1 to PC2.qinq.JPG
Configuration of Master is:
vIOS-L2-01(config)#vlan 100
vIOS-L2-01(config-vlan)#ex
vIOS-L2-01(config)#int gi0/0
vIOS-L2-01(config-if)#switchport access vlan 100
vIOS-L2-01(config-if)#switchport mode dot1q-tunnel
vIOS-L2-01(config-if)#no shut
vIOS-L2-01(config)#int gi0/1
Can someone please let me know where I was mistaken.
Giuseppe Larosa
Hello @active.hub2 ,
I would suggest to test using two Master switches with an 802.1Q trunk between them carrying outer VLAN 100.
As in real world a minimal setup I have done with real devices was that.
SW1 ----  802.1Q tunnel ---   Master1 ---   trunk ---- Master2 --- 802.1Q tunnel --- Sw2
if even the proposed setup does not work you may be facing a limitation of emulation SW
Hope to help
Giuseppe
Hi Giuseppe,
I tried the same topology as suggested by you.
Configuration of Master1 is:
vIOS-L2-01#show running-config int gi0/0
Building configuration...
Current configuration : 129 bytes
interface GigabitEthernet0/0
 media-type rj45
 negotiation auto
end
vIOS-L2-01#show running-config int gi0/3
Current configuration : 132 bytes
interface GigabitEthernet0/3
 switchport mode trunk
 media-type rj45
 negotiation auto
end
Still ping does not work from PC1 to 2.0.0.2.  I tried sniffing on the links LINK1 and LINK2.  On LINK1, I could see ARP req for 2.0.0.2 with vlan tag 2.  But on LINK2, I do not see any ARP req.
