QoS - 400Mbps limit how to handle
Hi all,
Hope to find everyone well in these troublesome times.
It's the following, I have a situation at work where I have a link limited to 400Mbps (two switches end to end using policing and with the action to drop) and I have my 1Gbps uplink connected to this link.
Unfortunately, I can't change the configuration on those two switches but I know they are dropping packets since it's giving exceed when doing the show policy-map command in the interface.
The only thing I can do is try to mitigate this by changing the way my Cisco 3650 operate the port.
I created a policy-map where I stated using shaper command to average at a max of 350Mbps in order to prevent the packets from hitting the max of the switches doing policing, but unfortunately it didn't worked.
Can anyone help me please in a way where I can put my QoS to limit and take the blunt of the traffic before it reaches the 400Mbps link where it's being dropped?
18 Replies 18
Thank you very much Joseph
I grabbed your post and presented it to my managers, they were having a hard time understanding what I was saying and your post explained everything in detail.
Thank you for that. I think finally my costumer is going to get more bandwidth... let's see how it goes
Hi all,
I need to reopen this topic once again due to having some doubts in one of the priority queues.
I configured another site with a similar config but this time my pipe is 500Mbps instead of 400, my config is more precisely this one:
policy-map VIDEO_IN_REMOTE
class VIDEO_IN
set dscp cs4
policy-map system-cpp-policy
policy-map VIDEO_IN_SERVER_COMS
class VIDEO_IN
set dscp cs4
class SERVER_COMS
set dscp ef
policy-map VIDEO_OUT
class VIDEO_OUT
priority level 2 420000
class SERVER_COMS_OUT
priority level 1 10000
queue-buffers ratio 10
class class-default
policy-map ALL_TRAFFIC
class class-default
shape average 470000000
service-policy VIDEO_OUT
but I'm constantly having drops on the Priority level 1 queue as per below... (this queue is only serving one machine and setting a DSCP value of EF)
Service-policy output: ALL_TRAFFIC
Class-map: class-default (match-any)
0 packets
Match: any
Queueing
(total drops) 4906252
(bytes output) 86872034088
shape (average) cir 470000000, bc 1880000, be 1880000
target shape rate 470000000
Service-policy : VIDEO_OUT
queue stats for all priority classes:
Queueing
priority level 2
(total drops) 0
(bytes output) 84047645870
Queueing
priority level 1
(total drops) 4455948
(bytes output) 165268500
Class-map: VIDEO_OUT (match-any)
0 packets
Match: dscp cs4 (32)
Priority: 420000 kbps, burst bytes 10500000,
Priority Level: 2
Class-map: SERVER_COMS_OUT (match-any)
0 packets
Match: dscp ef (46)
Priority: 10000 kbps, burst bytes 250000,
Priority Level: 1
0 packets
Match: any
(total drops) 450304
(bytes output) 2659119718
I don't care if the data is lost on the default queue but where I didn't want it to be dropped is on the priority queues.
Is my config for the priority 1 queue not good? Is there something else that I can do to improve this?
Thank you for your help
Have you tried increasing the burst parameter?
Hi Joseph,
unfortunately is not possible I get this output:
priority burst cannot be configured for this interface
Configuration failed on GigabitEthernet1/0/20
Right now I have the interface configured like this:
class VIDEO_IN
set dscp cs4
class VIDEO_IN
set dscp cs4
class SERVER_COMS
set dscp ef
class VIDEO_OUT
queue-buffers ratio 30
queue-limit dscp cs4 percent 100
queue-buffers ratio 60
queue-limit 2000 packets
class class-default
class class-default
