QoS implementation question between core switch and access switch
trptplayer1
Community Member
Am working on implementing QoS in a building in our district. Which switches need this command: ?mls qos trust dscp? and what switch needs ?Auto Qos? enabled?
Here is the breakdown of this buildings network:
1 - Cat 3750 - core switch w/ IP routing enabled (only 12 gig ports)
4 - Cat 3560 - access switches with PoE ports for our phones and some data ports
4 - Cat 3550 - access switches - data ports
2 - Cat 2950 - access switches - data ports
Here is the auto QoS config from the Cat3560 ? an access layer switch.
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2 1
mls qos srr-queue input cos-map queue 1 threshold 3 0
mls qos srr-queue input cos-map queue 2 threshold 1 2
mls qos srr-queue input cos-map queue 2 threshold 2 4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
mls qos srr-queue input dscp-map queue 1 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3 32
mls qos srr-queue input dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2 33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2 49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3 32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
(text deleted)
interface FastEthernet0/1
description VLAN 110: IP phone
power inline never
switchport access vlan 110
switchport mode access
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
interface FastEthernet0/2
power inline never
mls qos trust cos
Should Auto Qos be enabled on each switch that supports it?
Thanks for any help
Dan
mchoo2005
Level 4
Level 4
I also recommend "auto qos voip trust" configured on your 3560's uplink port to the 3750G-12S.
Do you also have CCM server connected somewhere? Or are you using CME?
Thanks for the tip. I'll put it in there tomorrow. By CCM do you mean cisco call manager. Or is CME - Call manager express?
Dan
I have "auto qos voip trus" configured on one of the 3560 switch's uplink ports. Do you think I need the massive config of auto qos --mls qos map....mls qos srr-queue input bandwidth....all of those commands generated from auto qos. Do I need those on the 3560 or on the 3750 Core switch?
A cisco engineer working on our other buildings in our district sent a sample config for a 3560 with these configs (a short config):
msl qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos map ip-prec-dscp 0 8 1624 32 46 48 56
mls qos
(text deleted)
interface fa0/1
description ip phone
switchport access vlan110
priority queue-out
mls qos trust dscp
We as a staff asked for help since he wasn't contracted to program this building.
What do you think of the above config?
Dan
