QoS in Switch L3
Chriskoh
A new challenge for me which our organization is going to rollup MS TEAMS very soon. However, I stuck those requirements how to apply QOS in our L3 switches that requested by our voice vendor as below:-
  • Voice, Video and File sharing traffic originating from Windows clients should be tagged with DSCP markings
  • L3 switches should be configured to identify the real time voice and video traffic based on the DSCP bits tagged done by Windows clients.
  • Once the application is classified, appropriate prioritization and reservation can be set
  • Voice traffic should be part of Priority queue on switches
  • Recommend increasing the buffer size for video queue to handle any addition burst traffic
What is the easiest way to configure to give voice priority and requirement as above? Note that ONE switch port has 2 vLANs (data and voice). It will connect through hard phone first in Vlan 20, then from phone connecting to PC (PC in vlan 10 has configured the QOS in windows registry file as below):
  • Audio DSCP value 46
  • Video DSCP value 34
  • Screen sharing DSCP value 18
** Hard phone is non cisco phone and it has DSCP value of 46
Our voice traffic flows as follows: PC & Hardphone  => Switch 2960x based   => Firewall => edge router  => local internet breakout
I provided our current L3 switches port interface configuration and there are no class map, policy map or access list in place. The mls qos in our L3 switch is enable.  I need you to give me technical advise by giving me a draft configuration in L3 to meet those requirements, so I have an idea how the configuration works in voice priority
interface GigabitEthernet1/0/26
 switchport access vlan 10
 switchport mode access
 switchport voice vlan 20
 priority-queue out
 no snmp trap link-status
 mls qos trust dscp
 spanning-tree portfast
 spanning-tree bpdufilter enable
end
Thanks in advance
5 Replies 5
Leo Laohoo
Classic IOS switches can operate fine with "default" or no QoS enabled.
Deepak Kumar
As shared information is only for the interface but we need actual QoS configuration details. As you mentioned that you are using 2960X in your network so I am sharing QoS guide for the same:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/qos/configuration_guide/b_qos_152ex_2960-x_cg/b_qos_152ex_2960-x_cg_chapter_011.html
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Thanks for your reply, Deepak.
As below is a test configuration which i am trying.
As said that PC softphone has a DSCP value of 46 (EF) for Audio, DSCP value of 34 (AF41) for PC video and DSCP value of 18 (AF21) for PC screensharing. All have been registered in PC windows registries as QOS in Vlan 10. For hardphone in Vlan20 has DSCP of 46 (EF). Therefore, i configured "mls qos trust dscp" for port interface as i trust PC and hardphone in DSCP.
Besides, i created ACL to match PC traffic based on source ip and destination port numbers. Then i can match this ACL in class-map and create a policy map to trust these traffic. However, i have an error when i apply the policy on that interface as below. Anyone can assist to fix this error? Also i have no ideas how it works for the "class-map match-all Class-TmsDscp" ?.  what i want is any packet ip header consist DSCP values for ingress, match the conditions against the DSCP values ( EF, AF41 or  AF21) that i've listed, then apply the policy and trust DSCP. Maybe my conditions are not making sense which i wanted all these voice traffics to set high priority.  Please enlighten me.
-ip access-list extended Tms_AllTraffic
 permit ip 172.30.0.0 0.0.255.255 any
 permit tcp any any eq 5067
 permit udp any any eq 5067
 permit tcp any any range 3478 3481
 permit udp any any range 3478 3481
 permit tcp any any range 50000 50059
 permit udp any any range 50000 50059
 exit
-class-map Class-TmsAccess
 match access-group name Tms_AllTraffic
 exit
-class-map match-any Class-TmsDscp
 match ip dscp AF21
 match ip dscp AF41
 match ip dscp EF
 exit
-policy-map Tms_Policies
 Class Class-TmsAccess
 Trust Cos
 Class Class-TmsDscp
 trust dscp
  exit
/*** Port Interface ***/
 priority-queue out
 mls qos trust dscp
end
/*** Error while applied the service policy into port interface ***/
switch#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
switch(config)#int gig1/0/26
switch(config-if)#service-policy input Tms_Policies
QoS: class(Class-TmsDscp) match ip can be used only with match protocol in a match-all class [GigabitEthernet1/0/26]
Service Policy attachment failed
what image are those switches running ? If you have anything higher than LAN Lite, you can also consider Auto-Qos...
See below:-  Do you think auto QoS is really help ? I read through some Cisco forums with regards auto QoS , sometimes it doesn't fit into the organisation as those people comments. Have your organisation use AutoQoS? If so, how is the performance for voice traffic?  One thing i really don't understand if the hardphones & PC softphones have those dscp values of 46 itself, those port interfaces which i indicated "mls qos trust dscp" , should my "policy-map" indicated "trust dscp" before i apply into those port interfaces ? Or should i remap it "set dscp 46"?
Switch Ports Model SW Version SW Image
* 1 28 WS-C2960S-24PS-L 12.2(55)SE7 C2960S-UNIVERSALK9-M
Please advise and thanks
