QoS Output explanation
Steven Williams
Level 4
Level 4
I feel like voice is not being prioritized here:
show policy-map interface te1/1/8
TenGigabitEthernet1/1/8
Service-policy input: AutoQos-4.0-Trust-Dscp-Input-Policy
Class-map: class-default (match-any)
16478161787 packets
Match: any
QoS Set
dscp dscp table AutoQos-4.0-Trust-Dscp-Table
Service-policy output: AutoQos-4.0-Output-Policy
queue stats for all priority classes:
Queueing
priority level 1
(total drops) 0
(bytes output) 136147824710
Class-map: AutoQos-4.0-Output-Priority-Queue (match-any)
0 packets
Match: dscp cs4 (32) cs5 (40) ef (46)
Match: cos 5
Priority: 30% (300000 kbps), burst bytes 7500000,
Priority Level: 1
Class-map: AutoQos-4.0-Output-Control-Mgmt-Queue (match-any)
0 packets
Match: dscp cs2 (16) cs3 (24) cs6 (48) cs7 (56)
Match: cos 3
Queueing
queue-limit dscp 16 percent 80
queue-limit dscp 24 percent 90
queue-limit dscp 48 percent 100
queue-limit dscp 56 percent 100
(total drops) 0
(bytes output) 6199759013
bandwidth remaining 10%
queue-buffers ratio 10
Class-map: AutoQos-4.0-Output-Multimedia-Conf-Queue (match-any)
0 packets
Match: dscp af41 (34) af42 (36) af43 (38)
Match: cos 4
Queueing
(total drops) 0
(bytes output) 567440735
Class-map: AutoQos-4.0-Output-Trans-Data-Queue (match-any)
0 packets
Match: dscp af21 (18) af22 (20) af23 (22)
Match: cos 2
Queueing
(total drops) 0
(bytes output) 20080413
Class-map: AutoQos-4.0-Output-Bulk-Data-Queue (match-any)
0 packets
Match: dscp af11 (10) af12 (12) af13 (14)
Match: cos 1
Queueing
(total drops) 0
(bytes output) 37314031504
bandwidth remaining 4%
Class-map: AutoQos-4.0-Output-Scavenger-Queue (match-any)
0 packets
Match: dscp cs1 (8)
Queueing
(total drops) 308337
(bytes output) 1515137314849
bandwidth remaining 1%
Class-map: AutoQos-4.0-Output-Multimedia-Strm-Queue (match-any)
0 packets
Match: dscp af31 (26) af32 (28) af33 (30)
Queueing
(total drops) 0
(bytes output) 469986461
0 packets
Match: any
Queueing
(total drops) 6098893
(bytes output) 75775201575413
bandwidth remaining 25%
queue-buffers ratio 25
CAO-MDF-9300-01#show run int te1/1/8
Building configuration...
Current configuration : 483 bytes
interface TenGigabitEthernet1/1/8
description CORE 4500X (Te1/1/9)
no switchport
ip address 10.53.0.82 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf 10 area 0
auto qos trust dscp
service-policy input AutoQos-4.0-Trust-Dscp-Input-Policy
service-policy output AutoQos-4.0-Output-Policy
end
CAO-MDF-9300-01#
Joseph W. Doherty
How are your VoIP frames/packets tagged?
