question about ether channel
Dr.X
Level 2
Level 2
hi ,
i want to ask about etherchannel  and especailly , why we type the command
#channel-protocol pagp
or
#channel-protocol lacp
i mean we can type desirable , auto ,on for pagp,
but why we need to type the command
currently im confusing and see that the command
has no need to be written .
plz advice about my issue
regards
kcnajaf
Level 7
Level 7
Channel-protocol command is for setting whether you want to use Cisco's original, but proprietary, PAgP protocol for etherchanneling or you will use the IEEE standard LACP protocol.
Depending on protocol you keywords for the mode command will differ (LACP has active and passive where PAgP has desirable and auto).
The "channel-protocol" command is optional. Use the channel-protocol command only to restrict a channel to LACP or PAgP.
See the output below.
Switch_Test(config)#int range f0/21 - 22
Switch_Test(config-if-range)#channel-group 1 mode desirable
Creating a port-channel interface Port-channel 1
Switch_Test(config-if-range)#end
Switch_Test(config)#int range f0/23 - 24
Switch_Test(config-if-range)#channel-group 2 mode active
Creating a port-channel interface Port-channel 2
Switch_Test#sh etherchannel
                Channel-group listing:
Group: 1
Group state = L2
Ports: 2   Maxports = 8
Port-channels: 1 Max Port-channels = 1
Protocol:   PAgP
Group: 2
Group state = L2
Ports: 2   Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol:   LACP
Switch_Test#
Notice how the switch understand which protocol to use based on the mode selected.  However, when we select "on" as the mode, since both PAgP and LACP use the "on" as an option for the mode the switch now does not know which protocol to use.  See the output below.
Switch_Test(config)#int range f0/1 - 2
Switch_Test(config-if-range)#channel-group 3 mode on
Creating a port-channel interface Port-channel 3
Group: 1
Group state = L2
Protocol:   PAgP
Group: 2
Group state = L2
Protocol:   LACP
Group: 3
Group state = L2
Protocol:    -
Switch_Test#
If you set the protocol by using the channel-protocol command, the setting is not overridden by the channel-group interface configuration command.
Hope that helps
Najaf
Please rate when applicable or helpful !!!
kcnajaf
Level 7
Level 7
Group: 1
Group state = L2
Protocol:   PAgP
Group: 2
Group state = L2
Protocol:   LACP
Switch_Test#
Group: 1
Group state = L2
Protocol:   PAgP
Group: 2
Group state = L2
Protocol:   LACP
Group: 3
Group state = L2
Protocol:    -
Switch_Test#
Hope that helps
Najaf
hi  najaf ,
thkns forur reply ,
now i concluded that the channel-protocol command is needed whenwe choose the moe to be on
in this case the no negotioation so , we have to type
channel-protocol  command .
and also i concluded that channel-protocol command   overides the the mode negotation
mean if there was both , negotation and channel-protcol command , the etherchannel will get the protocol typed in
plz  give me an Ack , if my two points above were correct .
regrads
My mistake...
I didnt realise deleting one of my replies will delete all other replies behind it even though i have selected to delete only one post:-( Sorry for that.
Like Peter said "mode on" can not be used with channel protocol command. When you select "mode on" etherchannel will form unconditionally with out any protocol (ie without PagP or LACP protocols).
Coming back to your above two points...
1) I have tested this now on a live switch and we can not have "mode on" and "channel protocol" under the same interface. The switch will through the error message as below if you try to configure both under same interface.
Switch(config)#int range fas 0/23 -24
Switch(config-if-range)#channel-group 1 mode on
Switch(config-if-range)#channel-protocol lacp
% Range command terminated because it failed on FastEthernet0/23
00:53:36: %EC-5-ERRPROT2: Command rejected: the interface Fa0/23 is already part of a channel with a different type of protocol enabled
2) For the second point if you configure the switch to negotiate  (for example let us assume we configured switch port to negotiate to PagP using desirable at one end and auto at other end) and on top of this you try applying the "channel-protocol" the switch would again reject this with below error message.
Switch(config)#int range fas 0/23- 24
Switch(config-if-range)#channel-group 1 mode desirable
Switch(config-if-range)#channel-protocol pagp
Command rejected (the interface Fa0/23 is ): is already part of a channel with a different type of protocol enabled
On the other hand if the interface already have the "channel-protocol" set (assume the channel protocol is configured to PagP) and if we try to set the group for LACP below error message will be generated by switch
Switch(config-if-range)#channel-group 1 mode passive
01:47:55: %EC-5-ERRPROT: Channel protocol mismatch for interface Fa0/23 in group 1: the interface can not be added to the channel group
So in short we can see here that "channel-protocol" command does not have much role...
Hope this helps.
Najaf
Peter,
Thanks a lot for your explantion which made me to lab this up :-)
mahmoodmkl
Level 7
Level 7
the rther channel will form if the other side also configured with mode on.
the on mode is like statically configuring the ports
