Question about feasibility in using a C2960 24TT-L for a very special situation
essax_ltd
I'm fairly new to Cisco products and IOS and therefore I would need help to figure out if the following
situation could be solved in using a C2960 24TT-L ( with  c2960-lanbasek9-mz.150-2.SE2)
and if so, what would be the commands to configure.
We are testing in our test lab special devices and such a device has one ethernet interface,
configured by firmware, with 4 IP addresses (192.168.255.1,192.168.255.33, 192.168.255.34
and 192.168.255.35) and gateway address 192.168.255.126.
Now the idea is to link 20 of such devices to the C2960 and assigning to the gigabitEthernet port
routed/NATed  IP addresses, as example:
fa port 1:  192.168.255.1     <->   10.47.187.10
fa port 1:  192.168.255.33   <->   10.47.187.11
fa port 1:  192.168.255.34   <->   10.47.187.12
fa port 1:  192.168.255.35   <->   10.47.187.13
fa port 2:  192.168.255.1     <->   10.47.187.14
fa port 2:  192.168.255.33   <->   10.47.187.15
fa port 2:  192.168.255.34   <->   10.47.187.16
fa port 2:  192.168.255.35   <->   10.47.187.17
and so on.
We can choose the IP,s for the gigabitEthernet port but the device IP's  are fixed.
I know that this is not the typical situation for such a product like the C2960
but would simplify our test lab management and so I'm asking if someone can
tell me if this would feasible in using our C2960.
Thanks in advance.
6 Replies 6
Jeff Van Houten
Level 5
Level 5
NAT occurs at a layer 3 boundary. The 2960 is a layer 2 device. The switch can't create NATs.
Thank You for Your answer.
Hmm, but it's interessting becuase according to
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swipstatrout.html
it has L3 cababilities with 12.2_55 or newer, but You are right, seems to be without NAT support and without
it might be not feasable.
But at least it can route:
Switch#show sdm prefer
The current template is "lanbase-routing" template.
The selected template optimizes the resources in
the switch to support this level of features for
0 routed interfaces and 255 VLANs.
  number of unicast mac addresses:                  4K
  number of IPv4 IGMP groups + multicast routes:    0.25K
  number of IPv4 unicast routes:                    4.25K
    number of directly-connected IPv4 hosts:        4K
    number of indirect IPv4 routes:                 0.25K
  number of IPv6 multicast groups:                  0.375k
  number of directly-connected IPv6 addresses:      0.75K
  number of indirect IPv6 unicast routes:           0.5K
  number of IPv4 policy based routing aces:         0
  number of IPv4/MAC qos aces:                      0.125k
  number of IPv4/MAC security aces:                 0.375k
  number of IPv6 policy based routing aces:         0
  number of IPv6 qos aces:                          0.375k
  number of IPv6 security aces:                     127
Is is not that "it seems". As correctly mentioned above already, access switches do not do NAT. For that, you need a router.
Also, do not realy on these switching for routing, as that is not what thye have been designed for.
Good morning,
In general You are right, we just thought we could use it for that  purpose because we
have several laying around and due the announcement that with a newer IOS it's cabale
to route.
Wolf
Good morning:
It's documented, catalyst fixed and 4ks do not support NAT.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a008011c629.shtml
Regards.
Wilson B
Good morning,
Sorry but I couldn't find the 2960 in that document.
Wolf
