Question??? Catalyst 2960-S-48FPD-L & Supported SFP Modules
datencio1
I have five Catalyst 2960-S-48FPD-L switches and needed to know if this SFP+ module will work in it:  GLC-LH-SM.  I have the the GLC-SX-MM modules in them now, which are working.  However, I get no activity on the GLC-LH-SM modules.  I have gone over the following link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/hardware/installation/guide_stack/HIGOVERV.html#wp1250224 , and might be misunderstanding it.  I need to know if I can use them or have to return them,  any help in the matter would be appreciated.
Thnaks,
Daniel
Arumugam Muthaiah
Hi Daniel,
Yes, SFP module GLC-LH-SM will work with switch WS-C2960S-48FPD-L, please see the detail below,
Product:
WS-C2960S-48FPD-L
WS-C2960S-48LPD-L
WS-C2960S-24PD-L
WS-C2960S-48TD-L
WS-C2960S-24TD-L
Supported Transceiver Module
GLC-SX-MM
GLC-LH-SM
GLC-ZX-SM
GLC-BX-D
GLC-BX-U
CWDM SFP
GLC-SX-MMD
GLC-LH-SMD
Minimum IOS release: 12.2(53)SE1
Refer:
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html#wp128965
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
